Results 1 to 3 of 3
Thread: Grounding a concrete tank
  1. #1
    Join Date
    Apr 2008
    Posts
    372
    I have a problem, we have been asked to come up with a grounding scheme for a concrete tank. Normally no problem, slap a few ground rods and cadd weld to the rebar. Our civil guys have spec-ed out the rebar as epoxy coated and that is my problem, attaching to the rebar won't work. Anyone else encounter a situation like this and how did you get around it?
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,378
    If it were a swimming pool you would make your own bonding grid out of 8AWG copper. Same principle should work for your tank.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  3. #3
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,206
    have them add some uncoated rebar just for you to connect to.
    why are you "grounding" a concrete tank? and what are you "grounding" it to are important questions to answer first though.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
