Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: half switched receptacle
  1. #1
    Join Date
    Sep 2013
    brooklyn, new york
    Posts
    153
    Is half switched receptacle can be feed from two different load.
    From lighting load and room receptacle load.
    What is your opinion on this?
  2. #2
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,827
    I've never supplied receptacles from a load. I supply them from the circuit.
    But can you split a duplex with two circuits? Yes. You just need to make sure the two circuits have a common disconnect.
  3. #3
    Join Date
    Sep 2013
    brooklyn, new york
    Posts
    153
    Quote Originally Posted by 480sparky View Post
    I meant with the circuit. I guess I'm working to much.
    The thing is, I argued with other PM that you can supply half switched receptacle from two different circuit.
    Thank you for your respond.
  4. #4
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,275
    What code section is that? I've never seen a handle tie or common disco to split receptacles, tho most I work on were installed 30+ years ago. Come to think of it, I dont think we did that on the last house we wired (oops?).
  5. #5
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by michalspike View Post
    It is not you, it is 480, he has a hard time being nice.
  6. #6
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by JFletcher View Post
    In the 2008 it is 210.7(B).
  7. #7
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,275
    Quote Originally Posted by iwire View Post
    Thank you. Yep, we (and the inspector) missed that one.
  8. #8
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,827
    For quite a while, the common-disconnect rule applied only to dwellings. However, it's applies everywhere now. I'm not sure when it changed.
    Some folks just don't have a sense of humor.
  9. #9
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    No problem and none of us know all the code.
  10. #10
    Join Date
    Mar 2007
    Branson, Missouri
    Posts
    301
    I am certainly among those ranks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
