Results 1 to 10 of 10
Thread: Houses sheathed with asphalt board/cardboard
  1. #1
    Join Date
    Aug 2012
    Changed for anonymity
    Posts
    269
    This has stumped me for some time now.
    Is there any way to secure a meter, service cable or just about anything to a house that has siding over asphalt board/cardboard? or even the newer houses that use high-R foam? You'd be lucky to get 1 of a 2-hole strap to hit a stud and a 16"+ length of strut would be ridiculous. Am I suppose to cut open finished walls to add blocking?
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    7,929
    If it's just a meter or breaker box I have no problem using quarter inch toggle bolts into the siding. If it needs to be more solid Unistrut on the surface, spanning the void and screwed into the studs works for me.
    Once in a while you get shown the light
    In the strangest of places if you look at it right. Robert Hunter
  3. #3
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    5,533
    Quote Originally Posted by ActionDave View Post
    to make it a bit less fugly, there are snap in covers for strut that are PVC, and give it
    a bit more of a finished look. cut to fit, move on.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  4. #4
    Join Date
    Jan 2007
    Massachusetts
    Posts
    2,392
    For the meter, longer screws into one stud, toggles for the other side. For the conduit or SE cable, toggles.
  5. #5
    Join Date
    Mar 2017
    Utah
    Posts
    1
    I always like to hit something solid like studs for support. If you don't you run the risk of the meter sagging from earth settling pulling down on the conduit over time.
  6. #6
    Join Date
    Feb 2003
    New Jersey
    Posts
    3,209
    Good luck with this stuff. I have it on my house. It's called Celotex. It's a good insulation product but a horrible replacement for sheathing. It's strong enough to hold a cedar shake nail but that's about it. When I had the shakes ripped off and vinyl siding installed the contractor wrapped the house with Tyvec but I had him mark where the studs were so that the new siding would be secured.
    In my case I mounted the meter enclosure and was lucky enough to hit a stud on one side of the meter. I like the toggle bolt idea but that puts a larger hole in the siding that can be subject to leaks. I also used 2" PVC for the service and spray painted it the color of the siding (yes, I'm married ) Chances of hitting a stud are minimal. Use at least 2 1/2: galvanized screws, deck screws or stainless screws.
    If you do some research on the web you'll find many sites regarding Celotex. This is one I found regarding lawsuits :
    https://www.asbestos.com/companies/celotex.php
    Again, good luck.
  7. #7
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    3,370
    If it has vinyl siding, you might be able unzip a piece or two, while carefully prying/cutting out the nails, cut out the asphault board, put in blocking from the outside, and put it back together. You could also span stud to stud on the exterior I suppose. Only time I've run across this stuff, the siding was being replaced anyway.
  8. #8
    Join Date
    Jul 2013
    Arcata, CA
    Posts
    319
    If the location is near some through the wall object, like a window or vent, perhaps you could find the stud from the inside of the wall and measure.
  9. #9
    Join Date
    Aug 2012
    Posts
    269
    The reason for revisiting this issue is I trying to strap 4/0 SEU to what I'm reading now is call homasote (which you can break apart with your hands).
    Most of the times I've come across this specific issue the siding was old and faded and popping it and adding support behind risks cracking the siding.
    The only thing about toggles that bothers me is the big hole you have to drill which usually means you have to put a large diameter washer behind the strap to cover the hole, silicone included of course.
    Anyone try Togglers? Smaller hole than standard toggle and when you set them with the zip strips i't a perfect time to fill with silicone.
  10. #10
    Join Date
    Aug 2009
    inside Area 51
    Posts
    490
    " Am I suppose to cut open finished walls to add blocking? "
    IMO, ...absolutely not !......Instead of mounting to the rickety wall, a type of
    metal stand constructed of unistrut could be set in the ground, in to concrete,
    close to the exterior wall, but yet, ...independent of the wall [ RE: Article 312.3,
    `08 NEC ].
Posting Permissions
  • You may not post replies
  • You may not edit your posts
