Has anyone here ever installed PVC COATED GAL(O CAL). Here is the question...why is it not found in the NEC?
i have been using this for many jobs and now the construction management company is asking questions. The job specs say to use O CAL conduit on the outside of the building and to stub into thru the foundation wall. We stubbed in at 18" and changed over to EMT. The CM is questioning the use of pvc inside. There is no where in the NEC that states that I cannot do this method. It does not state in the job spec that this cannot be done either. The conduit enters thru the foundation wall into non public space in the basement at approximately 9' above the floor in a 10' high electric closet.
Anyone have any input.
Thanks, Sparkcontrol. IBEW Local 3 NYC
Bookmarks
