Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Bid on small job trying to be fair on both ends
  1. #1
    Join Date
    Jan 2017
    United States
    Posts
    38
    I have a job coming up that I have to look at and from my understanding it is just a condo with attic access and they want to get some ceiling fan boxes installed with the fans and possibly some can lights on switches for all of them.
    My question is should I go in with a bid of per hour, and material; or should I simply just bid it per opening and what is a good per opening rate to charge. They live in a well off neighborhood and they probably aren't hurting for the cash but have a baby coming.
    Any thoughts on this would be great thanks guys.
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,018
    Quote Originally Posted by Doctor Electric View Post
    Your time is worth the same whether they are poor as church mice or siblings of Bill Gates with triplets on the way. If you've already surveyed the work you should have a good idea how you are going to perform it. Give them a fixed price and be done. No one is going to reduce your costs because you're a nice guy. You have to eat too.
  3. #3
    Join Date
    Jul 2005
    Posts
    775
    What would your per opening price be, and how did you come up with it?
  4. #4
    Join Date
    Jan 2017
    United States
    Posts
    38
    I think 50 bucks a space maybe what do you think
  5. #5
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,755
    Sounds pretty cheap to me
    Bob
  6. #6
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,345
    Ok, they want fans installed where there is none. So you are going to do them for $50 each? Let's see.....it takes an hour to locate where to cut the hole, cut hole, run wire, possibly having to cut in a switch, find/add a junction box etc.
    Then assemble and install the fan.
    All for $50?
    You should lay it out on paper, the cost of material and the time it takes to do it. Probably need to add some time because it always seems to take longer. Add your mark up on the material, then your profit, then your labor. I bet you come up with way over $50 to do all it takes to install a fan in an area that has no light or power.
    If you've done enough "virgin" installs for fans or can lights you can come up with a close "per each price". But if you just pull a number out of the air you won't be in business long.
    If you aim at nothing, you will hit it every time!
  7. #7
    Join Date
    Jun 2010
    Posts
    1,928
    Quote Originally Posted by gadfly56 View Post
    And the knowledge and experience to estimate accurately and bid accordingly is what helps you get future jobs as well as not lose money. Charity work should be seen as a time to take good notes on how long something takes. If you're working as an employee you just do the work as told and the billing issue is not your concern.
  8. #8
    Join Date
    Jun 2010
    Posts
    1,928
    There's between zero to what you'd like to mark up on materials. This is the slack you can use if you had to. Pay close attention to how you though it will go, how it went. Go home and check over what you estimated, how long it took you and any issues you've run into. Barely making anything on something new the first time is fine but you'll do it again if you don't keep track of why.
  9. #9
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by Electric-Light View Post
    You have never been an electrical contractor or even earned a living as an electrian have you?
  10. #10
    Join Date
    Sep 2008
    UK
    Posts
    10,531
    I'm with gadfly. Fixed price.
    I was in a different area - mostly industrial and that's the norm. But even in commercial or residential, look at it from the customer's POV. You would want to know how much the job will cost, not an open ended how much it could cost.
    Another point that gadfly indirectly mentioned - if they are as poor as church mice will they be able to pay you? Would you want an up-front payment to at least cover your material costs. Your supplier will want to be paid even if your customer can't/doesn't cough up.
    Yes, the commercial world can have harsh realities.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
