Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: E Stop switch
  1. #11
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,805
    Quote Originally Posted by CEDEng View Post
    totally right, bob - the "estop" word has only appeared in responses so far, not from the OP.
    Except for the title and all.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #12
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,537
    actually he called it an estop too, but that may just mean it is a big red button.
    Bob
  3. #13
    Join Date
    Apr 2013
    Kennedy Space Center, Florida
    Posts
    40
    Good Afternoon
    It is an e stop according to the Square D box. It has a break glass button holding contacts open.
    When you break the glass it releases the button making the circuit. It was requested by our fire dept.
    at each door to de-energize the MCC before entry in case of fire. That is the reason for the original install.
    During a PMI it was noticed the contact and screws were rusted and cracking the plastic contact block housing.
    I am replacing the contact block inside the e-stop.
    Our engineer was concerned about the load side wires "IF" anything could happen.
    Thank you everyone for the input.
  4. #14
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    For what it is worth the function you describe makes it not an emergency stop. Emergency stops have very specific rules and a shunt trip would not be part of it.
    You are describing what many would call an 'EPO' Emergency Power Off button.
  5. #15
    Join Date
    Apr 2013
    Posts
    40
    Thank you. I thought as i was reading that i might have the wrong name for the switch itself.
    I changed out the contact block with out indecent so all's well that ends well.
    I appreciate everyone's help.
  6. #16
    HA sheesh you're right - right there in the topic. I only referred to the body, where it wasn't mentioned.
    not enough coffee...too much coffee...old age...hard to say...
    Sounds like you're all resolved, but I agree with what was previously posted: This is an EPO circuit, emergency power off, not an ESTOP. Semantics perhaps, but you'd get very different responses about this if it were indeed an ESTOP.
  7. #17
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,141
    Post #5 by the OP:
    The chances seem remote that while replacing the e stop switch....
  8. #18
    Well, at this point on March 17 and a Friday - it's too much beer, coffee's not in the equation...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
