Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Power Strips vs. Extension Cords vs. Additional Receptacles
  1. #11
    Join Date
    Jan 2007
    New Jersey
    Posts
    1,043
    The use of plug in transient voltage surge suppressors avoids the restrictions of extension cords.
    Rick Napier
    Inspector and Instructor
  2. #12
    Join Date
    Jun 2015
    nyc
    Posts
    121
    I don't understand why plug strip is allowed and extension cord isn't allowed. both connected to receptacle on the wall, the only difference that plug strip has 15A switch/protection built-in. how the second one significantly reduce fire hazard?
    Sent from my Nexus 5X using Tapatalk
  3. #13
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,368
    A 10 amp extention cord will catch fire if overloaded before it ever trips the 20 amp breaker.
    Sent from my SCH-I535 using Tapatalk
  4. #14
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,130
    Quote Originally Posted by Coppersmith View Post
    The key here is overloaded, not shorted.
    mobile
  5. #15
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    It is a listing violation to use multioutlet strips etc with a cord.
    If you do not violate that it will be hard to overload it.
  6. #16
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,368
    Plug a 10 amp extention cord into a wall outlet. Plug two 10 amp portable heaters into cord. Overload! No power strip required.
  7. #17
    Join Date
    Oct 2013
    newburgh,ny
    Posts
    431
    Non-permanent
    Quote Originally Posted by electrofelon View Post
    We frequently run into extension cords having to be eliminated at commercial occupancies after a fire inspection. I am not sure about the specific chain of laws that grant the fire marshall authority on this but Im sure its there.
    Extension cords in a manfacturing facuilty shall not be used for permanent wiring, is the reason I get.
    Cube tapes or multigang adapters are not allowed either due to heat build up, but a surge strip is.
    Cowboy
    A cowboy may get thrown , but they always get up and walk forward.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
