Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: That dreaded vaulted ceiling clearance
  1. #11
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,868
    This is a sloped can .....
    Brought to you by Carl's Jr.
  2. #12
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,330
    In architecture like this I have never seen can lights. Besides being the wrong choice it's just plain ugly. I've always seen pendent or chain hung fixtures, usually two rows, one row down each side. To augment that, it's usual to have track or separate flood fixtures on both beams up front to illuminate the altar.
    -Hal
  3. #13
    Join Date
    May 2015
    Philadelphia suburbs, PA USA
    Posts
    45
    The problem with pendants is they will obstruct the view to the chancel area. This is a church but without the pews. It's more of a multi purpose room that on some occasions require more light than on a Sunday service. I'm going to sample a standard shallow housing with a Comercial Electric gimbal 835 lumens and then check my concerns which are heat and enough of a tilt to shine straight down. I will post some more pics to give a better idea of this space. They want a contemporary look at the end so maybe something surface mount can still work.
    Pics to follow get ready to turn them to the right. Even if I send them already turned they come out turned again I have no idea why so sorry bout that. These two were taken yesterday standing on the chancel or stage area. They simply put out rows of chairs for the Sunday service. Other times for AA meetings or whatever it's wide open with tables set up and chairs per whatever the function is. Thx again I do appreciate the feedback any idea is a good one.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	17105   Click image for larger version.
  4. #14
    Join Date
    May 2015
    Posts
    45
    Track lighting last resort trying not to end up there.
  5. #15
    Join Date
    Jun 2003
    Posts
    3,330
    How low do you think they need to be? Place them about where the present lighting is and let them hang maybe 3 feet. Can't be any worse than that duct work. Your biggest problem is going to be finding suitable fixtures that complement the space. You need to look at commercial lighting, Home Depot isn't going to cut it. You're probably going to save money because you're not going to need as many.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
