Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: Underground PVC size transition
  1. #11
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by peter d View Post
    Probably because of this:
    That would do it.
    So maybe 1.25 from there to the section of 2" and stay with 2" there after?
  2. #12
    Join Date
    Mar 2003
    New England
    Posts
    13,184
    Quote Originally Posted by iwire View Post
    That would do it.
    That would work.
    Besides, for a 60 amp feeder, 2 #6, 1 #8 and 1 #10 will fly through a 1.25" conduit like greased lightning, even with the transition.
  3. #13
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,160
    The reasons I don't want to run 2" on the other end are:
    1) I had to add a subpanel on the main panel side because panel was full. Biggest KO on subpanel is 1.5".
    2) I have to core drill through a concrete filled block wall. I hate core drilling and the larger the size, the more I hate it.
    3) Pipe is going to be exposed inside garage for about 15' and I had a hard enough time trying to sell this idea with 1.25". Pretty sure 2" would be a no go. Plus it's snaking behind the legs of a storage cabinet. 2" may not fit there. If I were to come through the wall just below the subpanel it would look a lot nicer but would require trenching 20 feet in a very bad area (full of bushes and other pipes).
  4. #14
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,515
    There are also "swedge reducers" which are presumably easier to pull through:
    https://www.platt.com/platt-electric...px?zpid=476361
    Cheers, Wayne
  5. #15
    Join Date
    Mar 2003
    New England
    Posts
    13,184
    Quote Originally Posted by Coppersmith View Post
    In that case, I would install the pull line before backfill as suggested, and use the reducers.
  6. #16
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,160
    Quote Originally Posted by wwhitney View Post
    Cheers, Wayne
    Nice, but $35 each!
  7. #17
    Join Date
    Aug 2013
    New York, NY
    Posts
    427
    Nice, but $35 each!
    I call $35 to solve that problem (correctly) a bargain! How much is your time worth?
    SceneryDriver
  8. #18
    Join Date
    Dec 2014
    Sharps Chapel, TN
    Posts
    3
    Well, first of all if I am understanding your installation you're taking a 60 amp service out to a detached garage that is 100 feet away. If in fact this is true then your trench should have been at 24 inches and not 18 inches.
    And because it is a detached garage you will need a main breaker as a means of disconnect in your panel.
  9. #19
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,652
    Quote Originally Posted by electrict dave View Post
    You don't necessarily need a main breaker because you can still use the 6 disconnect rule.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  10. #20
    Join Date
    Apr 2006
    Springfield, MA, USA
    Posts
    3,058
    What is the length of the 2" 'sleeve'?
    As I understand it, the reason you can't simply slide some 1.25" through the 2" sleeve is because of the bell ends for joining lengths of 1.25". But if you had a long enough length of 1.25" you would have no problem, correct?
    Would a flexible NM raceway be suitable for the entire run, something continuous with no joints in the middle?
    -Jon
Posting Permissions
  • You may not post replies
  • You may not edit your posts
