Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Marking out panel for conduit
  1. #1
    Join Date
    Jan 2012
    Ny Hudson valley
    Posts
    460
    Witch is more accurate way to mark out conduit entering top of back box.
    I usually first take a piece of deep strut witch the conduit will be supported on
    befor entering panel .
    and make my back line with the deep strut , then I'll take a connector put it up to the back line
    and the get my halfway mark of the connector .
    is their a chart that gives you the half way mark of the diff sizes of conduit ?
    is this the method you guys use or do you use the conduit its self ?
  2. #2
    Join Date
    May 2009
    Usa
    Posts
    1,498
    Sharpie, strut or straight edge or ✏️
  3. #3
    Join Date
    Oct 2016
    US
    Posts
    33
    http://www.southwiretools.com/tools/m/tools/MM01
    Mean something like this?
    Sent from my SM-N900P using Tapatalk
  4. #4
    Join Date
    Jan 2012
    Ny Hudson valley
    Posts
    460
    Quote Originally Posted by KnightPower View Post
    I just YouTube it that tool looks like it would save a lot of time
    what you guys think .
    but until I get it is the connector halfpoint or the conduit of point better to use
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,157
    If you use strut to mark the back edge of your KO's with 2" and smaller EMT the tubing will be crooked because the EMT diameter is smaller than the actual KO. You would need to adjust the line about 1/16"-1/8" of an inch if you want the vertical conduit to enter plumb. I usually measure the actual cutter from the KO set and use that dimension to layout the KO's and adjust for the smaller EMT.
    Rob
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,262
    As Rob says depends on what kind of raceway you are using. EMT is smaller then the KO. RMC/IMC is approximately same size as the KO.
  7. #7
    Join Date
    Jan 2012
    Ny Hudson valley
    Posts
    460
    Quote Originally Posted by kwired View Post
    So for emt using the center point on the cutter of the knock out kit is most accurate .
  8. #8
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,841
    Quote Originally Posted by liquidtite View Post
    Yes..... that's what I do.
    Brought to you by Carl's Jr.
  9. #9
    Join Date
    Jan 2012
    Ny Hudson valley
    Posts
    460
    Sounds good
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,157
    Depends if you want to lay a piece of strut across the top of the panel and make a line for the back of all of the KO's it's not going to work correctly if you are using 2" of smaller EMT. If you make the correction to that straight line then you do not need to use the center of the KO.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
