Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: 20A recep on 15A circuit?
  1. #31
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,801
    Quote Originally Posted by Buck Parrish View Post
    A 20 amp outlet on a 15 amp circuit and breaker is considered deceiving. If the home owner is out shopping for treadmills. They may look at the male plug (with one prong turned side ways) and say oh we have those.
    Yet, a single 20 amp receptacle seems to be allowed on a 15 amp circuit. A typical example of why we shouldn't use the code as a design manual.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #32
    Join Date
    Feb 2003
    Wisconsin
    Posts
    9,851
    Quote Originally Posted by K8MHZ View Post
    I think it is....(C) Intention. This Code is not intended as a design specification or instruction manual for untrained persons.
    Definitely, I have erred in this regard.
    So much for posting by memory.
    I find some solace, in the NECH commentary appearing to agree that the relationship is between the type of document and qualifications.
    Just because you can, doesn't mean you should.
  3. #33
    Join Date
    Jun 2013
    Massachusetts
    Posts
    41
    Quote Originally Posted by infinity View Post
    The NEC allows a 20 amp single receptacle on a 15 amp circuit. If you overload the circuit the OCPD will protect the conductors.
    I don't think it does, what code article? What I see and read on 210-21 (B)(1), it states a single receptacle installed on an individual circuit shall have an Ampere rating not less than that of the branch circuit. 20A receptacle has to be on an 20A circuit.
    Sorry disregard my post I read the article wrong.
  4. #34
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,921
    Quote Originally Posted by lordofthisworld View Post
    I know that this seems to go against logic but it is code complaint to have a 20 amp single receptacle on 15 amp circuit.
    Rob
  5. #35
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,178
    I'm willing to bet the average HO don't know there is a difference between a 5-20 and 6-20 receptacle until the appliance cord will not fit whatever they have.
    Why do some treadmills have a 20 amp cord cap? Do they really draw that much load? Isn't the user supposed to do most of the work and not the machine? Can a single person exert 120x20=2400 watts of energy for anything other then a very brief period of time?
    I've seen thousands of conveyors, augers, etc. that do more work then those treadmills and draw same or less VA.
    Never could figure that one out.
  6. #36
    Join Date
    Mar 2008
    Posts
    9,801
    Quote Originally Posted by kwired View Post
    Treadmills use up so much electricity because of the friction of the belt, or 'tread' against the 'floor' of the treadmill needs to be overcome.
    Marky the Sparky
  7. #37
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,178
    So the 400 pound guy using the treadmill loads the thing much more then a 95 pound woman even though he is walking at 1-2 mph and she is maybe running at 8-12 mph for a good deal of her workout?
    Another thought: The "crawler" on my mini excavator is more efficient then that
    What happened to energy codes?
  8. #38
    Join Date
    Mar 2008
    Posts
    9,801
    I am pretty sure you are correct. A Kill-a-Watt would tell for sure. Or you could just listen to the motor groan and guess.
    Treadmills are horribly inefficient. They are also dangerous.
    I see that it is more common than I thought for treadmills to have 20 amp plugs. The term used in the industry seems to be 'dedicated circuit plugs'.
    Marky the Sparky
  9. #39
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,178
    Only ones I have seen with 20 amp plugs were some pretty pricey treadmills, not the relatively cheap ones you buy at Wal-Mart.
    I did some wiring for a fitness center when they first opened, all their treadmills had 20 amp cord caps. I always though of monitoring one while in use just to see what it draws. But those cost more then I would ever spend on one for use at home.
    Friend of mine once told me the doctor told him he needed to walk more. He said he can walk all day if carrying a gun
  10. #40
    Join Date
    May 2014
    AZ
    Posts
    2,286
    ??? 6-20 ???
    just like many other specs, NEMA has a goofy system. the 5-20 is not a "5-20", its a 5-15/20
Posting Permissions
  • You may not post replies
  • You may not edit your posts
