Results 1 to 8 of 8
Thread: Occupancy Sensor
  1. #1
    Join Date
    Nov 2016
    Dublin, GA
    Posts
    161
    Occupancy Sensor
    Can anyone recommend a good occupancy sensor for controlling lighting in a warehouse?
  2. #2
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Not much information to go by, but have installed some of these.
    Leviton
    If you are even thirsty, you are two quarts low.
  3. #3
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,365
    Quote Originally Posted by Fnewman View Post
    what type of controls are you using? do you want something that controls individual lights?
    do you want to do row by row, light by light, etc?
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  4. #4
    Join Date
    Nov 2016
    Dublin, GA
    Posts
    161
    Probably row by row control. Have looked at the Lutron and think their devices would likely work out ok, but just wondering if anyone has found anything better for industrial use.
  5. #5
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,769
    If the row is long enough, you may not be able to get by with a single sensor per row.
  6. #6
    Join Date
    Apr 2007
    Posts
    6,365
    depends on the scope of what you are doing. just adding occ sensors,
    if the fixtures are older stuff not suitable for frequent cycling, isn't
    going to turn out well. if you are using something like T5HO high bays,
    putting individual sensors on each light works well.
    if your hog has gone wild, and you have skylights, you can do daylight
    harvesting on 0-10 volt fixtures, and combine it with a lighting control
    system such as nLight, for virtually limitless capabilities, and cost.
    you can do partial on, timer controlled, access controlled, or factor
    in the phases of the moon, and astrological data as to what to do
    if neptune is in uranus.
    how wild is your hog?
  7. #7
    Join Date
    Nov 2016
    Dublin, GA
    Posts
    161
    After discussing with Lurton technical support a couple of times, I decided to go with their wired high bay sensors (two per aisle) and their DV power packs (PP-DV) installed in a custom designed panel to be wall mounted. If I don't forget I'll let you know how it worked in about 6 months
  8. #8
    Join Date
    Apr 2003
    Planet macmikeman
    Posts
    3,402
    I've recently placed an order at Graybar for 8 Enerlites ceiling mount occ sensors and 8 wall switch occ sensors. Never have tried em before , but I like the idea that they will take 277 v directly or 120 volts, and no need for outside relay packs for a low voltage switching system. This makes me work less if it delivers as promised. I will let the forum know when I get around to installing and commissioning the system on the commercial project I am contracting.
    85deg. an Sunny today.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
