Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: Conductor insulation rating
  1. #11
    Join Date
    May 2013
    Massachusetts
    Posts
    2,297
    Quote Originally Posted by wwhitney View Post
    The "sunlight resistant" marking? The data sheet you referenced adds that marking for sizes above 8 AWG.
    Cheers, Wayne
    No. What I mean is, what am I missing on that datasheet, regarding my understanding that the THWN-2 rating would apply to all sizes?
  2. #12
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,716
    Quote Originally Posted by elmundogrande View Post
    Here in California we just started using NEC 2014. So all I wanted to do is get the word out cause the AHJ are catching on to the #10 conductor insolation for wet location is 75* THWN, but on blue prints its still showing it as THWN-2 and all the math is at 90*C all wrong so be aware before you do and they make you change it out.
    I don't think they stopped making it, your suppliers may have stopped purchasing it that way though.
    All it takes is one bean counter in the supply company that wants to save a dime on every 100 feet purchased to make something like that happen.
  3. #13
    Join Date
    Mar 2014
    Utopia
    Posts
    1,287
    Facts- Manufacturers have not stopped making THHN/THWN-2 is smaller sizes. They just might offer an option that doesn't include the "-2" component which can create an issue for engineers who's specs do not specify the proper nomenclature but thats another topic all together.
    As additional info, the trend now is to create an "ALA CART" approach to wire manufacturing. For example, not all THHN/THWN-2 or XHHW-2 for that matter will be VW-1 rated. The customer (ultimately the distributor) can offer to have a wire with multiple ratings such as VW-1, FT-4/IEEE 1202. Now, FT-2 is mandatory for UL 44 but not for UL 83. Now, when UL 83 is to be VW-1 rated then it must pass both FT-2 and VW-1 to obtain such a mark. Interesting enough, the FV-1 test is the base minimum test for UL 83 (Thermoplastic wire) in the US and Mexico at this time...in Canada it's FT-1 but you get the jist.
    Anyway, point is....it used to be that wire and cable folks threw everything on the wire....now they most throw the minimums required and allow the end user to select the level of testing to be marked on the wire.
    *All code responses are based on the 2017 National Electrical Code[NEC]
  4. #14
    Wire for sale
    Quote Originally Posted by kwired View Post
    When I check with some local electrical suppliers and big box stores they only had 14-10 in THHN - THWN and when I called South Wire they said they only make it in THHN - THWN-2 in size #8 and larger
  5. #15
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    3,780
    Quote Originally Posted by MasterTheNEC View Post
    I am just dying to know, how much more it costs to add these various ratings - RHH-2 vs just USE-2, sun-res, -2, FT, CT use, etc. I really have to guess that it is very minimal cost adder and the added simplicity for everyone, less product variety, production runs, and stock would make it worthwhile.....I can dream.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  6. #16
    Join Date
    Mar 2014
    Utopia
    Posts
    1,287
    Well.....you have to understand the context of a production that runs 24/7-365. It is a huge cost factor when millions of feet are produced.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  7. #17
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,716
    Which only comes to 20 cents per hundred feet, maybe a dollar?
    Demand will dictate they make what will sell, problem is the bean counter at the supply house decides to save that 20 cents to a dollar for every hundred feet. Nobody notices much of anything until inspectors start noticing people are using conductors only rated 75C in certain conditions as 90C conductors. When enough supply house customers demand -2 conductors they may eventually lay down that extra 20 cents to a dollar to ensure that is what gets ordered.
  8. #18
    Join Date
    Mar 2014
    Utopia
    Posts
    1,287
    Huge costs to Manufacturer's and it adds up when we produce millions of feet a month. Also in many cases the pellets for thermostat already have specific additives and thermoplastic required additives placed into the mixture and indeed .30 a foot adds up when dealing with millions of feet Per Color......Per Product and so on. Most of the time VW-1 Is only in THHN/THWN-2 while it's optional in both T and X....
  9. #19
    Join Date
    Mar 2014
    Utopia
    Posts
    1,287
    So where did you get this value "Which only comes to 20 cents per hundred feet, maybe a dollar?"
    Do you assist in wire manufacturing?
  10. #20
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,716
    You do pass those costs on when selling the product don't you?
    It is the those purchasing on a wholesale level that determines what is available at supply houses and retail outlets. If you make it and their customers demand it, they will buy it. The bean counters at the supply house only see dollars and don't always see those minor differences or know what the buyer wants, until the buyer lets them know what they want. They will pass any extra cost on when they sell also, once they learn the buyer still prefers that product. Some may not realize there is no -2 rating until they encounter inspectors that are looking for it where needed.
    I haven't looked at any of the conductors I have purchased for some time now, maybe need to check to see if there is still a -2 rating on what I have been getting. You kind of assume that is what you are getting when you noticed it was there in the past.
    Bottom line is it isn't that -2 conductors are not manufactured, it is the middle man that determines what is available at supply houses and retail outlets. Any supply house employee that tells you they don't make it is wrong. What they should tell you is they don't have it.... because they are too cheap to buy it
Posting Permissions
  • You may not post replies
  • You may not edit your posts
