Results 1 to 3 of 3
Thread: NEC Crane Power Requirements
  1. #1
    Join Date
    Jul 2015
    CA USA
    Posts
    114
    Hi,
    I am confused about section NEC 2011 Section 610 "Crane and Hoists." Typically in my projects we are only responsible for the main AC power to equipment. I have a project with a bridge crane and was told to provide main power. There is a bridge crane installer that will handle the rest. I'm looking at 610 and have some questions:
    1. Table 610.14(A) - Do I use this table for power between my main 480V panel board and the crane controller (in lieu of the typical 310.15(B)(16)), or is this table only intended to be applied to the "runway conductors?"
    2. Are "contact conductors" the same as "runway conductors." Are these the typically the "festoon cables" that run between the hoist motors and the crane controller?
    3. 610.31 versus 610.32 - Does 610.31 apply to the main power between the source panelboard and the crane versus 610.32 which applies to the power between the "runway conductors" and the "hoists?" So basically I'm only responsible for the disconnect as it applies to 610.31?
    4. What are "secondary conductors" in relation to this section?
    Thanks for your help!
  2. #2
    Join Date
    Jan 2018
    Seattle
    Posts
    8
    I'm also confused by this section. Why doesn't Table 610.14(A) show ampacities for aluminum conductor?
  3. #3
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,606
    Quote Originally Posted by jlee405 View Post
    I approved your thread so you can each get your own replies.
    See here:
    http://forums.mikeholt.com/showthread.php?t=188975
    "Electricity is really just organized lightning." George Carlin
    Derek
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
