120V power from UPS to flush mounted LV enclosure (prev in gen elec forum)
Note: trying here after no response in general electrical.
I need to run 120V power to a flush-mounted Leviton structured wiring enclosure that will contain satellite/catv equipment.
The power needs to come from a UPS. The enclosure will be mounted in a wall of a wiring closet, the UPS will be in a rack in the same closet.
I'm having trouble figuring out how to do this. If it was a surface mount enclosure I would just run a flexible cord from the receptacle box on the enclosure direct to the UPS.
Because the enclosure is flush mounted, I'm "in wall" so I assume that I need to use NM-B for the in-wall portion of the run, then somehow exit the wall and transition to flexible cord at that point? Seems like a lot of work for a 10 foot wire run.
Just wondering if I'm making this too complicated and there is a better way.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
