Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Intermittent HDMI Cable??
  1. #11
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,574
    Quote Originally Posted by hbiss View Post
    This is why cables from a TV should NEVER be installed so that they can't be easily changed. Smurf tube, large enough so that the connectors can pass through and installed so that the cable can be easily pulled through is the proper way. HDMI can be finicky and I would never install a cable into a wall like a romex run and count on it to work when the TV is installed.
    You do know that cables over 25 feet utilize active connectors and only work one way with a definite in and out? I've never looked at testers for HDMI cables but I'll bet the cheap ones only do the shorter ones with straight through copper.
    -Hal
    If the cable is installed backwards will it work at all, or will it work intermittently?
  2. #12
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,565
    Will not work.
    I have seen what seemed to be intermittent problems caused by an incompatibility between a cable box and a TV. Like I say, HDMI protocol is finicky. It isn't just a method of moving data from one device to another, it also handles security by allowing a TV, for instance, to tell a blue ray player that it is authorized to display the content in HD because it's not some kind of recording device to copy the disc.
    -Hal
  3. #13
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Will not work.
    That's known as HDCP... High-bandwidth Digital Content Protection.
    I will have achieved my life's goal if I die with a smile on my face.
  4. #14
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,574
    Will not work.
    -Hal
    I take from that that the hdmi is not run backwards?
  5. #15
    Join Date
    Mar 2003
    Perry, Mi. Shiawassee
    Posts
    71
    After all we can buy a multi meter for $10 but no pro would use one of those.[/QUOTE]
    a $10.00 or $20.00 multimeter will do most field work quite handily and if dropped, stolen or fried won't be a significant loss.
    jerryalan
  6. #16
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,695
    Quote Originally Posted by jerryalan View Post
    a $10.00 or $20.00 multimeter will do most field work quite handily and if dropped, stolen or fried won't be a significant loss.[/QUOTE]
    True, but also consider some of those may blow up in your hand if you have it set on ohms and connect the leads to voltage.
  7. #17
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    I admit a fair amount of ignorance when it comes to HDMI, but ponder this:
    a good 80% of reception problems are on the customer end, and usually from bad terminations of CATV. How do you know that the HDMI cable isnt simply exacerbating problems on the CATV side of this? Is this a mfg'd or field-terminated cable?
  8. #18
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,574
    Quote Originally Posted by JFletcher View Post
    The customer tells me the picture is also bad when connecting to a DVD player. I assume that leads to bad hdmi cable or bad jack on the tv. I suggested to try a different hdmi input on the tv. Have notecard back.
    What I don't get is how a hdmi cable or jack can work intermittently. I imagine the contacts don't heat up and cause this. I would think the connection would be good or bad all the time.
  9. #19
    Join Date
    Jun 2003
    Posts
    3,565
    Only way to find out is to substitute a new cable. There are times where I had to fall back to a component connection (3 RCA video + 2 for audio) to make the devices work together.
    How is the customer using one HDMI cable from the TV to multiple devices? Or is he just switching the cable from one to the other?
    -Hal
  10. #20
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,574
    -Hal
    I don't know. He just hired me to run the hdmi and power to the tv. He wanted to take it from there.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
