Results 1 to 5 of 5
Thread: LEDs in New Construction - Class 2
  1. #1
    Join Date
    Aug 2003
    Posts
    26
    New construction, planning on using some low-profile LED fixtures, rather than installing traditional cans. Something like this: https://images-na.ssl-images-amazon....L._SL1200_.jpg
    (not necessarily that exact fixture, I just grabbed something of the sort for visual reference)
    I believe that to install per code, these need:
    NM cable @ 120V run to a Class 2 listed power supply. Power supply being an in-wall power supply unit, a surface-mounted unit, or one installed in an accessible box.
    Class-2 In-Wall rated wire from power supply to fixture locations
    Connections at fixture locations with WAGO connectors, inline splices, or some other permanent connection (no box)
    Seems pretty straightforward, but I wanted to make sure I have it right before forging ahead.
    Thanks
    Dave
  2. #2
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,000
    I'm curious as to your preference to use these vs traditional housing and LED trim.
    All of them I've seen have a power supply that installs in the ceiling above the fixture, and have a short 6" or so lead to connect the LED.
    Brought to you by Carl's Jr.
  3. #3
    Join Date
    Aug 2003
    Posts
    26
    Quote Originally Posted by brantmacga View Post
    The traditional housing route is a bit of silliness when you think about it.
    Install an expensive housing that's designed around a 100 year old light bulb design (~$20 for a 4" airtight IC housing)
    Buy expensive trim for the housing and an LED bulb designed to look like a 100 year old bulb, or buy a retrofit LED lens/housing (~$30)
    In for $50 per fixture and there is a ton of unnecessary equipment above the ceiling that's not needed. Plus, they can't be installed directly in line with a truss or rafter.
    Or use a purpose-made lamp where a single LED driver can run multiple lights. Picked up a 7-light kit, UL listed, IC rated, for $180. Half the price of the retrofit route, and I can hopefully get a tighter seal at the ceiling as well. Planning on running the romex to an outlet inside a kitchen cabinet. Surface-mount the sizable power supply, then run it's output back into the wall to the fixture locations.
    Also picked up a 4-light set with a power supply that'll fit inside a 4" square box. Placing that inside the adjacent closet with a blank cover plate on it.
  4. #4
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,771
    Quote Originally Posted by ddecart View Post
    New construction, planning on using some low-profile LED fixtures, rather than installing traditional cans...
    Also Known As "Disk Lights", surface mount to 4" light box, direct connect to 120v building wiring.
    Roger Ramjet NoFixNoPay
  5. #5
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,000
    Man that's super high. I pay $7 for an IC housing and $14 for a Satco LED trim. Plus, the trims just look nicer than the disk light.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
