User Tag List
Results 1 to 4 of 4
Thread: 410.136(G)(1).
  1. #1
    Join Date
    Sep 2009
    Posts
    43
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    410.136(G)(1).
    I would like some help with a code change that I would like to submit. Right now, article 410.36(G)(1) does not require a luminaire disconnect for led lights that utilize a driver. I would like to amend that section to include a requirement for a disconnect for luminaires that utilize aled driver. I will include the changes in bold.
    410.36(G)(1) General. In indoor locations other than dwellings and associated structures, fluorescent or led luminaires that utilize double-ended lamps an contain ballast(s) or driver(s) that can be serviced in place shall have a disconnecting means either internal or external to each luminaire. For existing installed luminaires without disconnecting means, at the time a ballast or driver is replaced, a disconnecting means shall be installed. The line side shall be guarded.
    The double-ended bulb part. Does that need to be reworded as well?
    The problem this will solve. This change will address the lack of required disconnect for led luminaires that use a driver.
    What do you think?
  2. #2
    Join Date
    Sep 2009
    Posts
    43
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    More on the double-ended lamps. What about led's that use strips of led's as opposed to lamps? How do I word that?
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,001
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I looked at a few of the old ROP's including the original {410.73(G)-2005 NEC} for this requirement and couldn't find any info that specifically referenced the reason for only double ended lamps. The good news is that for few code cycles the CMP re-wrote the language from the original proposal so the wording that you choose may not be that critical as long as your substantiation is good.
    Rob
  4. #4
    Join Date
    Sep 2009
    Posts
    43
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That would be great if they modified the wording on this one.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
