Results 1 to 6 of 6
Thread: Trick
  1. #1
    Join Date
    May 2006
    Posts
    448
    Trick
    Why those questions are made so tricky? They are good for millenniums but not for old-tired minds. My answer should be (A) but also, my family had a "parking garage" in the house in South-America, and you cannot eliminate romex with a partial basement adding 3 + floors, so (D) apply too ... ???? LOL, maybe I should start thinking in retiring ...
    Attached Images Attached Images
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,921
    You would need to go back several code cycles for that question to even be applicable.
    Rob
  3. #3
    Join Date
    May 2006
    Posts
    448
    sorry infinity, I don follow you
  4. #4
    Join Date
    May 2006
    Posts
    448
    "You would need to go back several code cycles for that question to even be applicable." this question is for a 2017 license renewal
  5. #5
    Join Date
    Feb 2013
    Aspen, Colo
    Posts
    1,984
    D ---- used the KISS rule they don't give enough info to deny the residential part.
    CircuitRyder --- Unfortunately not all good ideas are code enforceable.
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,921
    Quote Originally Posted by Esthy View Post
    The limits for number of floors have been removed from the NEC. Now you would use the construction type to determine if NM is permitted. Look at 334.10.
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
