Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Question for the lighting guys
  1. #1
    Join Date
    Oct 2015
    US
    Posts
    521
    I have a customer who is interested in lighting up the front of his building with some color changing LEDs they would need to be pretty bright. I don't think a tape would work he also wants some type of DMX controller. Has anyone done this before if so what products did you use or recommend.thanks
    Sent from my SM-G935P using Tapatalk
  2. #2
    Join Date
    Mar 2010
    Lake of the Ozarks
    Posts
    1,031
    Phillips has a good line.
    http://www.colorkinetics.com/
    1N73LL1G3NC3 15 7H3 4BILI7Y 70 4D4P7 70 CH4NG3.
  3. #3
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,809
    My church does this with DMX controlled flood lights, installed high and pointing down to wash the walls. 3 story building, works great
    Moderator-Washington State
    Ancora Imparo
  4. #4
    Join Date
    Oct 2015
    US
    Posts
    521
    Quote Originally Posted by luckylerado View Post
    Can you control these with a DMX if so how and what do I need to make it work I never installed a DMX controller before
  5. #5
    Join Date
    Mar 2010
    Lake of the Ozarks
    Posts
    1,031
    Quote Originally Posted by nickelec View Post
    I am not familiar with the entire line but they have several controller and interface options. Keypads and touchscreen mostly as far as I know more like PLC. Why limit to DMX?
  6. #6
    Join Date
    Nov 2016
    Dublin, GA
    Posts
    161
    DMX is a common standard for theater lighting. Control of fixtures usually involves software running on a PC or iMAC into DMX interface hardware. DPRO is one software brand, but there are many others.
  7. #7
    Join Date
    Oct 2015
    US
    Posts
    521
    I just went to go look at the work he wants to install 5 wall washers with color changing LEDs that change at random any suggestions?
  8. #8
    Join Date
    Oct 2015
    US
    Posts
    521
    I should also mention that the area he wants to light is in-between windows and is about 3 feet wide
  9. #9
    Join Date
    Dec 2015
    Texas
    Posts
    126
    Inground? Wall Mount? How tall is the facade? You'll want to run with a narrow optic for whatever you end up choosing (ie, 15 degree beam spread or less because your wall is only 3'-0 wide). Lumenpulse works great but is the most expensive out of the manufacturers, but it's one of those things you get what you pay for. They have wall mount and in-grade options.
    Lumenpulse - ingrade (wall mount is similar but it gives you an idea) http://www.lumenpulsegroup.com/produ...color-changing
  10. #10
    Join Date
    Oct 2015
    US
    Posts
    521
    Quote Originally Posted by tw1156 View Post
    It would need to be a wall mount
Posting Permissions
  • You may not post replies
  • You may not edit your posts
