Results 1 to 8 of 8
Thread: Another Getting Windows Ready lockup.
  1. #1
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    8,520
    First thing, first project. Need my laptop and it hung up as I tried to shut down to travel. Thirty minutes and two attempted shutdowns later the message is still there. How long before I remove the battery to ensure a shutdown?
    Tom
    TBLO
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    2,955
    What is the message? Removing the battery probably won't do anything.
    -Hal
  3. #3
    Join Date
    Jun 2003
    Posts
    8,520
    Third time's the charm. PIA.
    Tom
    TBLO
  4. #4
    Join Date
    Jun 2003
    Posts
    8,520
    Quote Originally Posted by hbiss View Post
    -Hal
    "Getting Windows Ready"
    I always check to see if updates are pending when I shutdown and none were indicated so I'll pass it off as another Windows BF.
    Tom
    TBLO
  5. #5
    Join Date
    Jun 2003
    Posts
    2,955
    With most computers if you hold the power button down for about 5 seconds or more it will force a shutdown.
    Also, I would turn windows updates OFF.
    -Hal
  6. #6
    Join Date
    Jun 2006
    Ohio
    Posts
    20,482
    Quote Originally Posted by ptonsparky View Post
    The most recent update seemed to take a long time on that on my desktop, too.
    I'll never get there. No matter where I go, I'm always here.
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    17,265
    Check online for that message and recent update.
    I have seen a Windows update take as much as an hour stuck on a screen like that, especially if the machine is low on RAM memory.
  8. #8
    Join Date
    Jun 2006
    Ohio
    Posts
    20,482
    Quote Originally Posted by GoldDigger View Post
    If you've ever seen Windows stuck on "Shutting Down" or "Restarting", it is the same thing. More often than not it is a stuck program or service that will not shutdown via normal termination... just like some that get stuck while Windows is running and you try to End Task or Stop service through Task Manager.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
