Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Wrapping 120Vac Electrical cords in Aluminum Foil to Deter Pets
  1. #1
    Join Date
    May 2007
    Posts
    939
    I was asked if I thought wrapping common 120Vac appliance/lamp cords used a home was an acceptable or too dangerous of a practice?
    This person read they could deter their animals from biting/playing with electrical cords by wrapping them in aluminum foil.
    My first thought was not a good idea at all from a safety standpoint. The most obvious to me would be a concern about any possible nicks in a wire being made even more greatly exposed creating an even larger hazard.
    I told them I thought it was a bad idea but they were frustrated and insisted they wanted to try it to see if it might work.
    I told them if they insisted to inspect the cords for any nicks and apply with the power off. Remove promptly if it did not work.
    Does this idea bother me more than it should?
    Any additional reasons I might cite?
    - Resistance is Futile ..... (if less than < 1 ohm) -
  2. #2
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,813
    I have a cat that it just may give more enticement to play with the cord.
    Otherwise I see it as less of a hazard then using a cord in a wet location in general.
  3. #3
    Join Date
    Feb 2003
    Fl
    Posts
    16,901
    It would be about the same as Aluminum MC cable if you think about it.
    Roger
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,245
    Quote Originally Posted by roger View Post
    Roger
    True, except there is no path to ground from the foil.
  5. #5
    Join Date
    Feb 2003
    Fl
    Posts
    16,901
    Quote Originally Posted by gadfly56 View Post
    And given the fact that MC is not recognized as an EGC (see 250.118) means it may not always have a low impedance path the clear a fault either.
    Roger
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,158
    I would have no problem wrapping a cord in foil.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,825
    I prefer to use the spiral plastic wire bundle wrap. It is not as flexible as the cord itself, but good enough for most purposes.
    And IMHO it looks a lot better than foil.
    I would worry that people would think that I line my hat with it too.
  8. #8
    Join Date
    Feb 2009
    Posts
    9,158
    Quote Originally Posted by GoldDigger View Post
    I had completely forgot about old appliance cords having that metal strain relief until I read your post.
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,406
    I would use a spring like we use on barbecue flexible gas connections.
    Rob
  10. #10
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,165
    Coat the cord with hot pepper sause.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
