Results 1 to 7 of 7
Thread: Retaining wall lighting
  1. #1
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    I was hoping for ideas for a slanted retaining wall. The customer likes the look of the lights that are installed under the top of the retaining wall top plate, so to speak. Under the lip of the top plate. The issue is there is no top lip with this retaining wall. Feedback is appreciated
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,017
    What are you asking? How to install, design issues? What kind of wall, slanted away or toward where the light will be,????
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Quote Originally Posted by Dennis Alwon View Post
    I just realized I didn't post picture of retaining wall. As you can see the retaining wall slopes back.
    Attached Images Attached Images
  4. #4
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Customer likes this style. Since there is not a protruding​ lip, as a top plate, that style will not work.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	17349   Click image for larger version.
  5. #5
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,968
    If they want to light the entire span, look into linear facade lighting. I think for this application you would want an uplight fixture. Several companies make them; for exterior we use the Hubbell brand Security Lighting line. I've used LED Linear brand also on interior lighting, but I think they make an exterior fixture also.
    Brought to you by Carl's Jr. ©
  6. #6
    Join Date
    Dec 2015
    Texas
    Posts
    127
    Flex Tube LED in Channel
    I've used this product before in a similar application with an in-grade channel. The LED flex tube is UV resistant, spray resistant, etc http://www.acclaimlighting.com/produ...ube-se-sc.html
  7. #7
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,519
    Quote Originally Posted by JJWalecka View Post
    But it wouldn't take much to add a top cap now would it?
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
