Results 1 to 10 of 10
Thread: smart meter
  1. #1
    Join Date
    Feb 2015
    Canyon Lake,TX
    Posts
    152
    smart meter
    when a "smart meter" is pulled does it raise a flag down at headquarters? if I pull a "smart meter" in order to upgrade my Aunt Mary's decades old Federal Pacific eqiupement will the co-op know on Monday morning?
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,601
    Quote Originally Posted by enireh View Post
    They'll know within about 5 minutes.
  3. #3
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,557
    It depends on the POCO and how they use the meters. We have one POCO that uses most of the features of the meter and one that uses none of the features. They say they want to wait until the "bugs" are out of the meters before implementing some of the features.
    The one that uses some of the features will know within minutes if the meter is pulled. It updates every few minutes (maybe longer) and if it shows "lost service", they will send a lineman to investigate. If they see the meter has been pulled someone is in trouble!
    As I said, it depends on the POCO and whether they use the features or allow the meters to be pulled by others.
    If you aim at nothing, you will hit it every time!
  4. #4
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,492
    Quote Originally Posted by gadfly56 View Post
    yep. now, if you get a copy of the bill, and write down the meter number,
    and call the poco, and explain the meter will go down for a few hours as
    you are doing a safety inspection of the panel, and give them your license
    number, then they won't roll a line patrolman to investigate the outage.
    permission is easier to obtain than forgiveness.
    when you are done, don't forget to release the outage notification.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  5. #5
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,557
    Quote Originally Posted by Fulthrotl View Post
    That won't fly here!
    We no allowed to touchy the meter!
  6. #6
    Join Date
    Nov 2016
    US
    Posts
    100
    When a smart meter goes offline, it typically gives an alarm at the system operations center. If a meter blips then clears its no biggie. If a meter goes out and stays out for a few minutes, they dispatch a supervisor. If a cluster of meters go out and stay out, they dispatch a troubleman.
    Sent from my VS987 using Tapatalk
  7. #7
    Join Date
    Apr 2007
    Posts
    6,492
    Quote Originally Posted by Little Bill View Post
    i always ask before touchy da meter.
    i never, ever, reach out and grab a utility by da meter.
    they *hate* that.
    if there is a "pillars of hercules" lock band on it,
    i ask if they would please remove it first, and give
    them a couple days. with the realtime monitoring,
    they don't put the lock ring back on anymore
    unless it's a meter in a place like compton, or inglewood.
  8. #8
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,178
    As mentioned "it depends".
    Most of them usually "ping" the server they are associated with on a periodic basis, or the server pings each meter registered to the system. How many missed communication incidents is necessary to issue the operators a trouble alert and how often those happen is going to be different with nearly every POCO. Some could perform such communications every few minutes, some could do so once a day, week or month. I'd guess most are expected to transmit data at least once a day though.
    They not only use this system to detect individual service outages, but when there is a widespread outage, they can look at data of what is all out and help determine where the source of the problem may be before they even dispatch a repair crew.
  9. #9
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    5,753
    I agree that it's better to get permission.
    With some power companies and some jurisdictions it may not even be that big of a deal even if you let them know the panel is changed. There are still jurisdictions here where you can do a panel swap (same type) without a permit. There is a small fee for a meter reseal from the POCO it gets added to the power bill.
    The 95% of people that you can't trust give the other 5% a bad name.
  10. #10
    Join Date
    Oct 2007
    British Columbia, Canada
    Posts
    816
    Quote Originally Posted by kwired View Post
    The Itron meters have a capacitor that keeps it powered a couple of seconds, allowing it to send a "dying gasp" message when it looses power. Once power is restored they send a restoral message. Otherwise I think the normal status updates are 15 minute intervals.
    "The Doppler effect means red lights will appear to be green if you drive fast enough..."
    1) Wait for disaster 2) Determine it's not your fault 3) Blackmail the culprit 4) Profit
    Caution: Classless when exhausted from a tough day at work, may attempt to compensate with poor humor and Christmas cheer...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
