Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Concentric KO's
  1. #11
    Join Date
    Mar 2003
    New England
    Posts
    13,138
    Quote Originally Posted by electricguy61 View Post
    I have found that drilling out the points, that connect one ko to the next size, using a ⅛" bit, helps tremendously. Not sure how better to describe what we do.
    Great tip!
  2. #12
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    8,992
    I use my 3/8 unibit to do the same thing so if you are a little bit off you can drill one or two more steps.
    If Billy Idol or John Denver is on your play list go and reevaluate your life.
  3. #13
    Join Date
    Feb 2003
    Illinois
    Posts
    23,317
    For panel enclosures, I always specify that they do not have any knockouts. I much prefer to put the holes where I actually want them and not have to deal with the prepunched ones that really don't match up with any of the standard installation methods.
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  4. #14
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,156
    Quote Originally Posted by don_resqcapt19 View Post
    I couldn't agree more unless were running strictly MC cable to concealed panels (probably not an issue for you).
    We have in the past ordered KO's only on one end of the panel so you could use it either with or without KO's by flipping it over which gives some flexibility depending on the installation.
    Rob
  5. #15
    Join Date
    Feb 2009
    Posts
    8,992
    Man oh man do I agree. I think it should be opt in for pre punched panels instead of opt out.
  6. #16
    Join Date
    Feb 2003
    Illinois
    Posts
    23,317
    Quote Originally Posted by infinity View Post
    Not sure I know that the MC stuff is
    Don, Illinois
Posting Permissions
  • You may not post replies
  • You may not edit your posts
