Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Switch Debacle, LED Dimmer, Space, Please Help :/
  1. #1
    Join Date
    Dec 2014
    Los Angeles, CA
    Posts
    6
    I have a double gang electrical box that has wiring for a double dimmer switch (dual skylark dimmer) controlling two sets of recessed lighting and a timer module that controls a outdoor lamp by the door.
    The issue is after upgrading all the recessed lights with LED lights the dual dimmer module doesn't work properly. I assume its because it isn't LED compatible. The problem is there aren't ant dual LED dimmer modules currently available, which is amazing to me Is there ?
    At first i figured id install a larger three gang box and replace it with two individual dimmer switches. Upon removing the box i realized there is wood pretty much on both sides of the box, killing that thought.
    Are there any alternatives or creative solutions other than relocating the timer switch ?
    Thanks,
    Pete
  2. #2
    Join Date
    Jun 2012
    NW Ohio
    Posts
    948
    Cut the wood out.
  3. #3
    Join Date
    Dec 2014
    Los Angeles, CA
    Posts
    6
    Quote Originally Posted by mopowr steve View Post
    Cut the wood out.
    Is that even appropriate if its a wall 2x4 ?
    Pete
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,769
    Quote Originally Posted by pasta1234 View Post
    Pete
    I think that the response was tongue in cheek!
    On the other hand, if it is a non-load bearing wall, or closely adjacent to a double studded door frame it might not be out of the question. Get a signed and stamped determination from a PE.
    And you could always mount another box vertically above the existing space. A two gang with one blanked off might not look too bad.
    Or with the timer centered in it.
  5. #5
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    afaik, there are no dual dimmer LED rated single gang switches. Yes, we want this, right behind AFCI to go away forever.
    I agree with GoldDigger; mount another box vertical of the existing one. If the framing doesnt permit a 3+ gang box, forget the idea of gutting studs.
  6. #6
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,139
    If it's a non bearing wall I would cut the stud out.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  7. #7
    Join Date
    Dec 2014
    Los Angeles, CA
    Posts
    6
    This wall is the corner to the front door and a window, so I'm a little reluctant to do that?
    As I was staring at the problem I noticed that directly opposite of the lamp outside is a small closet with electrical inside for a light. Since this programmable switch really isn't ever used, is it acceptable to have it inside the closet?
    Pete
    Sent from my Moto G (4) using Tapatalk
  8. #8
    Join Date
    Nov 2016
    Dublin, GA
    Posts
    161
    Before going to all that trouble, do you know the lamps you installed are actually dimmable? Some LEDs are not. Might be worth trying it out of the wall first.
  9. #9
    Join Date
    Dec 2014
    Los Angeles, CA
    Posts
    6
    Box says dimmable..
  10. #10
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    Quote Originally Posted by ActionDave View Post
    While I'm fairly confident in my ability to determine if a wall is load bearing or not, I dont want the liability that can come with making structural changes w/o consulting an engineer. Im also going on the assumption that the framers arent throwing in extra, useless studs everywhere. I've seen far too many nail pops and drywall seams coming apart even if the framing is right to want to add to that.
    Besides, cutting the stud larger than the box size is pretty impossible, and fishing in new wiring on the opposite side of a stud is not the best thing imho.
    If it were a 5 gang box and you need 6, are you going to put and o/u switch in, cut in a 6 gang box, or a 1/2 gang above/below the existing box? Would it matter if it were wooden panelling or tile vs drywall?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
