Results 1 to 2 of 2
Thread: CL2 Limited Power Project
  1. #1
    Join Date
    Apr 2017
    Yep
    Posts
    1
    I am installing LED lights under my kitchen cabinets. I havea listed CL2 24v/96w power supply with an integrated NIMA enclosure thatprovides the required CL1/CL2 separation; I have listed CL2 14/2 cable. I planto run the load side cable in the walls to bridge the sink and cook top. Thepower supply is a low profile design that will tuck nicely in the recess belowthe wall cabinets. So now I am looking at hiding the cables; my goal is toavoid any cable running below the cabinet. Ultimately, I would like the cablesto pass through the drywall while still being hidden in the recess; a wallplate is too large to achieve my goal. Of course, it's all got to be codecompliant.
    Questions:
    1. Class 1NM needs a j-box to pass through a wall - but does that box need to be on theinside of the wall? Can I use the power supply's enclosure or another low profile box, mounted to thecabinet close to the wall, as the junction box?
    2. Sameissue with the CL2 cables. I would like to make my own wood face plates to coverthe hole in the drywall and be small enough to hide in the recess. The CL2cable would run directly from the power supply through a wall to the fixturewithout splice or a listed faceplate.
    Am I dreaming or even remotely close to making this an inspectionworthy system? Are there other listed fittings that I have not thought of? Dotell....
    R/
    Danny
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,374
    Unfortunately we can not help you with this project.
    This site is designed for:
    Contractors
    Electricians
    Engineers
    Inspectors
    Instructors
    Other electrically related individuals
    This NEC Forum is for those in the electrical and related industries.
    Questions posted that appear to be an attempt to gain assistance with an electrical installation will be removed. Forum rules prohibit us from assisting a person to perform or assist others to do electrical work who are not qualified. Mike Holt Enterprises and the Moderators of this Forum do not wish to place you and your family in danger, by allowing others to give you too little information to ensure that the installation is safe
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
