Results 1 to 5 of 5
Thread: Crawl space lighting
  1. #1
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Is there a code proposal that would require open lighting in a crawlspace to be physically protected.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	17468   Click image for larger version.
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,834
    No but due to someone breaking a lamp and a shock or electrocution?, crawl space lighting is now required to be GFCI protected.
    You can certainly put in a proposal, but due to the above I doubt it was pass.
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    They probably should be; I've smacked and broken more than one myself.
    If you can find accident reports involving crawlspace lighting, or carefully word a proposal, you may be able to get protection on crawlspace lights. Shock and electrocution are not the dangers that having sharp, hot, broken glass in your face/head are imo. I dont think it a bad idea but then again, here, crawlspace lights are an afterthought and done as cheaply as possible. There's usually one at the entrance and one near an HVAC unit, if it's lit at all.
    Electricians do it until it Hertz!
  4. #4
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,161
    I'm closing this thread. The OP isn't consistent with this forums rules.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2014 NEC unless otherwise noted.
  5. #5
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,133
    I have gotten pm's about why this was closed..If you read the rule that Bob posted you would see that this was posted in the code proposal forum. Nothing should be posted there except proposals.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
