Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: old metal 4" square boxes covers
  1. #1
    Join Date
    Mar 2006
    Essex, New Jersey
    Posts
    393
    I am working on a residential renovation, and found a lot of open boxes, that of course just need a blank 4" square cover. Any one knows if it is still available for this discontinued boxes?. I don't want to start cutting and drilling the new covers available for the new boxes now. Thanks for your responses
    Miguel
    All things, therefore, that you want men to do to you, you also must likewise do to them
  2. #2
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,239
    Well since you didn't show the box, that's going to be hard to answer.
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
  3. #3
    Join Date
    Mar 2006
    Essex, New Jersey
    Posts
    393
    Sorry about that. Sometimes you think that people see what you have in you mind.
    If you see , the meta tab where the threaded hole for the 6-32 screw use to be farther from the corner, The modern 1900's have them very close to the corner. So the distance from screw to screw is different from this old boxes. We can not put the modern blank cover because the slots do not align, so we have to cut or drill them. Very time consuming.
    Attached Images Attached Images
    Miguel
  4. #4
    Join Date
    Mar 2014
    Connecticut USA
    Posts
    74
    I found a bunch of those style blanks years ago at a local privately owned Hardware store on clearance as they were becoming a chain hardware store, check around there. I have also seen them online, I'll have to look at my bookmarks when I am home.
    Depending on how many you need, I'd just drill them out.
    I also have a few in my shop from jobs we've demoed over the years for just this reason.
  5. #5
    Join Date
    Jan 2013
    Albuquerque, New Mexico ,Untied States of America
    Posts
    270
    Hello,
    I am sure Garvin sells an accessory to screw them to the box, it's a little tab, checkout their website.
    Here's the URL for the tabs.
    http://www.garvinindustries.com/elec...b-converter/ec
    Quote Originally Posted by mtnelectrical View Post
    PJHolguin 8-)
  6. #6
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,821
    So you want to add holes to a UL listed cover?
    Bob
  7. #7
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,239
    Quote Originally Posted by petersonra View Post
    That's what he's trying to avoid.
    John Childress
    IAEI / CEI / C10
  8. #8
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,239
    Just a question are you sure that's not a 5s box?
    John Childress
    IAEI / CEI / C10
  9. #9
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,212
    Quote Originally Posted by cowboyjwc View Post
    Hmmm, could be, could be.
    Click image for larger version.
Name:	4 and 11-16 box.jpg
    or this, for a drawn box
  10. #10
    Join Date
    Feb 2007
    USA
    Posts
    5,403
    The OP's picture shows a old style 4s box where the ears are in a different place than modern 4s. Those Garvin adapters should work fine.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
