Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: garage door opener wiring
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    35,680
    Quote Originally Posted by Coppersmith View Post
    Isn't this called the "code forum"? If it was called the "hack forum", well then ...
    Actually this thread is in the low voltage and limited energy forum
  2. #22
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,309
    Oh, excuse me. I was fooled by the navigation menu on Mike's main page.
    Attached Images Attached Images
  3. #23
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,463
    Quote Originally Posted by kwired View Post
    I hear you and I would put it in the wall myself. Just wondering what those that follow every rule no matter how minor it may seem have to say.
    One wonders if they follow every rule or the just talk a good game.
    I know what I don't know, and I know where to go to find it!
  4. #24
    Join Date
    Feb 2013
    Aspen, Colo
    Posts
    1,979
    Quote Originally Posted by Strathead View Post
    None the less, it was a good point. That being, some cable is not listed for installing concealed in an wall, or ceiling cavity, so verify application or install a chase.
    The bell wire I see is marked CL2/CL3 which is good for the class 2 wiring of the garage door opener & in residential -- sometimes the marking is difficult to see -- I do agree cable not marked is not listed
    CircuitRyder --- Unfortunately not all good ideas are code enforceable.
  5. #25
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,467
    My opinion is:
    1) It's junk.
    2) You normally wouldn't have the opener on site until after the rough so where would you get it?
    3) Thermostat wire is listed so it can be installed concealed.
    4) Thermostat wire comes on a spool making it easy to pull vs a tangled mess.
    I would expect the door installers to use that stuff, enough said.
    ETA: If you use CAT6 instead of CAT5 the door will go up and down faster.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
