Results 1 to 2 of 2
Thread: Class 1 low voltage wiring in wall
  1. #1
    Join Date
    Apr 2017
    Monterey, CA USA
    Posts
    1
    I am looking for an approved method to run class 1 low voltage wiring in a wall from jbox to jbox. What kind of cable and what kind of cable clamps are approved?
    I have searched unsuccessfully for rated NM cable that contains just two 16 or 18ga. conductors. I've seen the MC luminary cable that contains two 14ga. conductors and two 16ga. low voltage wires (http://www.afcweb.com/mc-metal-clad-...s/mc-luminary/), but this is a 3-way circuit so I need three 14ga. conductors. I would also rather not use MC cable unless it is my only option.
    I did find a non-metallic wire sheath with a "UL Recognized" rating (https://www.grainger.com/product/TEC...Sleeving-1UXW6), so I could make my own cable from 16 ga. THHN wire, but would that be acceptable?
    The rest of the installation is complete: there are 10 ceiling boxes connected by conduit, for dimmable LED lighting. I just need to run the wiring to the dimmer switches.
    -Dave
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,671
    I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
    If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
    A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
