Results 1 to 2 of 2
Thread: Photovoltaic and Honeywell generator
  1. #1
    Join Date
    May 2017
    Pinckney Michigan usa
    Posts
    2
    Installing a outback inverter with 2 wire start for generator. Using a 11kw Honeywell generator I need to tie generator to in inverter. My question is how to I make the Honeywell in to a 2 wire start system?
    Thanks
  2. #2
    Join Date
    Jul 2009
    Mesa Arizona
    Posts
    260
    I have used several of these generator controllers. They can use a simple ON/OFF control and automate starting, even if a diesel with pre-heat, etc. Will not over-crank if generator fails to start. Best to purchase with the enclosure. Made in Canada.
    http://www.solarconverters.com/produ...rator-starter/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
