Results 1 to 10 of 10
Thread: Ohms on a branch circuit
  1. #1
    Join Date
    Sep 2014
    dallas tx
    Posts
    1,640
    If I were to check ohms from neutral to ground on a plug, what should it read ?
    The hardest faults to clear are mine
  2. #2
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,462
    Quote Originally Posted by electricalist View Post
    A receptacle or male cord end?
    Define plug.
    Tom
    TBLO
  3. #3
    Join Date
    Sep 2014
    dallas tx
    Posts
    1,640
    Sorry a receptacle.
  4. #4
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,467
    I'll answer your question with a question. Considering that the neutral and ground are connected together at the main panel, what would you expect to read?
    -Hal
  5. #5
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,439
    Unless the receptacle was the only one on the circuit, I would think return current on the neutral from other receptacles would mess up your ohm measurement,
    Ron
  6. #6
    Join Date
    Sep 2008
    UK
    Posts
    11,042
    I would expect not more than a few ohms.
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,071
    Quote Originally Posted by ron View Post
    The first step before taking an ohm measurement should be to check whether there is a voltage difference between the two points.
    To some extent the existence of an AC voltage difference may not necessarily affect the result of a DC ohm check. It depends on the test circuit design.
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,734
    I would guess less than 1Ω.
    Rob
  9. #9
    Join Date
    Sep 2014
    dallas tx
    Posts
    1,640
    We have a customer who bought a " plug" tester made by the people who make green tools. Not greenlee. He says if it detects 10 ohms or more it lights up red.
    I checked at the panel from neutral to ground ( all bonded at the first disconnect) it read 0. I checked at the outlets he checked and it read .01.
    Now he feels like he just got a bad tester and is gonna return it for another one.
    All bs aside I don't know enough info to give him a real answer or how to honestly explain what it should read safely.
  10. #10
    Join Date
    Jun 2003
    Posts
    9,462
    I would think it should "red" well before 10 ohms. Pure waste of pennies.
    Tom
    TBLO
Posting Permissions
  • You may not post replies
  • You may not edit your posts
