Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Sand Gas Line to bare metal
  1. #1
    Join Date
    Sep 2015
    Colorado
    Posts
    135
    Is there a specific code reference that says when bonding black iron it has to be sanded to bare metal? or is this up to the AHJ?
    Thank all,
    Cheers,
    WROBO
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,365
    I was always under the impression that the clamp is designed to go on the pipe without modification of the pipe. Now if the pipe after installation is painted you might need to remove the paint.
    Rob
  3. #3
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,704
    AFAIK the "teeth" in those bonding clamps are partly there to bite through paint, rust, etc.
    You sand off any coatings on the pipe and you invite corrosion to the parts not engaged by the "teeth".
  4. #4
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,326
    True, but black iron has no coating that is protective. If there is rust or paint I would sand it off.
    Why are you bonding a gas line anyway?
    -Hal
  5. #5
    Join Date
    Mar 2003
    New England
    Posts
    13,184
    I've never bonded a gas line in my life.
  6. #6
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    3,774
    Quote Originally Posted by peter d View Post
    How often to you have to educate inspectors that the gas line is bonded by the EGC serving the appliance? In my experience, there are only like 6 inspectors in the country that know that one
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,365
    CSST bonds are connected to the small section of black pipe adjacent to the meter everyday around here.
    Rob
  8. #8
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,539
    Quote Originally Posted by electrofelon View Post
    Post #7 (after yours) is part of the key. We finally get the point across that the EGC can serve as the bond then the CSST rules come into play and we have to use that word "except".
    My experience when there are variables, such as here or one vs two rods, etc., some contractors just tell there men to take the cautious road rather than have to go back.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  9. #9
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by hbiss View Post
    True, but black iron has no coating that is protective. ...
    Depends on what you consider protective. The black is lacquer. It'll prevent rust in damp locations.
    I will have achieved my life's goal if I die with a smile on my face.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,704
    Quote Originally Posted by Smart $ View Post
    I was going to ask what makes it black, because it isn't black below the surface.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
