Results 1 to 2 of 2
Thread: Best Grounding Practices
  1. #1
    Join Date
    May 2014
    AZ
    Posts
    2,229
    the techniques/methods to do so are somewhat well documented. see NFPA-780 as a reference. See Annex-C
    i like isolation method. PVC can give ~55kV/mm dielectric ability. sched80 PVC can provide about 267kV dielectric. thus, having a big down connector that has very little ohms is key.
    http://lightningsafety.com/nlsi_lhm/lpts.html
    http://www.bicsi.org/uploadedfiles/p...gLightning.pdf
    notice it says "use more ground rods", they must say that for a reason
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,369
    I moved this to it's own thread since it is more about lightning protection than it is about pools.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
