Results 1 to 5 of 5
Thread: Led driver wiring
  1. #1
    Join Date
    Jan 2007
    Michigan
    Posts
    699
    Led driver wiring
    I'm putting about 12 of these led fixtures in a soffit.
    https://www.amazon.com/gp/aw/d/B013O...M3L&ref=plSrch
    Led driver has a small input cable (22-2) with about a 5 or 6 inch long whip.
    What's the best way to wire these things?
    I was thinking about using handy boxes with strain relief (cord grip) fittings, since cable is so small, and mounting driver next to box.
    This doesn't leave enough cable to properly splice in box but I don't see what else I can do.
    Can I get away with just using a romex clamp?
    John,
  2. #2
    Join Date
    Jan 2007
    Michigan
    Posts
    699
    I'm not sure if this is the exact fixture I have but I wished I verified that it was listed.
    I read one review from an installer that said he put the driver in a metal box in case of cataclysmic failure, but I'm thinking it needs proper ventilation.
    John,
  3. #3
    Join Date
    Jan 2007
    Michigan
    Posts
    699
    No opinions?
    John,
  4. #4
    Join Date
    Nov 2016
    Kennewick
    Posts
    39
    It's a sealed unit put it in a box
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    32,102
    I have a feeling it is not listed. In the Q & A someone did ask about UL and didn't get a definiite answer either.
    some other similar products that were suggested said the were listed without having to look deep into details.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
