Page 15 of 15 FirstFirst ... 5131415
Results 141 to 146 of 146
Thread: Single Phase current draw for a 3 phase output VFD: technical discussion
  1. #141
    Join Date
    Sep 2008
    UK
    Posts
    9,230
    Quote Originally Posted by GoldDigger View Post
    Labels R as in Red, B as in Blue and G as in Green.
    No reference to "ground" except perhaps implied in the fact that the three AC lines are the voltages with respect to some common fixed point.
    And when the voltages plotted are line to line voltages, even that implicit reference is gone.
    Exactly that. With respect to each other. Line to line as you say. No common ground, fixed point, neutral, or reference required, inferred or implied.
    It would have been red, yellow (not green) and blue but yellow didn't show up too well so I picked another colour. Just so happened.........water under the bridge.......no pun intended.
    Si hoc legere scis nimium eruditionis habes.
  2. #142
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    17,061
    Quote Originally Posted by Besoeker View Post
    ... Just so happened.........water under the bridge.......no pun intended.
    That's alright. None taken.
  3. #143
    Join Date
    Sep 2008
    UK
    Posts
    9,230
    Rectified then.............
  4. #144
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,013
    170522-0907 EDT
    Smart $:
    G is just one of the three input lines along with R and B. The letters correspond with the colors of the plotted curves. Others have pointed this out.
    For convenience I would pick -DC output as the reference point, but note the AC input line that connects to -DC changes three times per cycle, and corresponds to the plotted waveform that is most negative.
    If you go to 12 diodes, 6 transformers, and appropriately connected primaries, then you may need virtually no output capacitor, and ripple will be small. About 1/2 of the 6 diode bridge.
  5. #145
    Join Date
    Sep 2008
    UK
    Posts
    9,230
    Quote Originally Posted by gar View Post
    170522-0907 EDT
    Smart $:
    This is something we have quite often done but with one transformer. Delta primary and two secondaries, one star (wye), the other being delta. Ddyn11. So called 12-pulse.
    It was for supply harmonic mitigation the lowest being 11th. But yes, it does reduce the ripple also.
  6. #146
    Join Date
    Jul 2013
    Renton, WA
    Posts
    584
    'And as an exercise for the student' -
    - take a look at the use of 126 transformers used for some megawatt high power high accuracy radar systems (where final DC ripple is only a few MICROvolts after added regulators) and the delta taps needed to feed the diodes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
