Results 1 to 7 of 7
Thread: whats your "go to" calculation sheet?
  1. #1
    Join Date
    Aug 2011
    New York, NY
    Posts
    25
    so many excel sheets, software, websites engineers used to calculate everything, what you do use?
    am trying to put a master excel sheet to pretty much do most of my calcs
  2. #2
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,471
    Maybe you post what you have so far and we can see if it can be augmented by others?
    Ron
  3. #3
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    I could probably add some to your sheet...
    I will have achieved my life's goal if I die with a smile on my face.
  4. #4
    Join Date
    Sep 2008
    UK
    Posts
    11,340
    Quote Originally Posted by mepengineer View Post
    I suppose it depends on what you are calculating.
    I seem to have been generating excel spreadsheets all my life................
    I don't think it have been done with a common master sheet.
    A couple of examples from my field - power electronics - might explain.
    Panel cooling air flow requirements.
    Harmonic spectrum.
  5. #5
    Join Date
    Jun 2003
    Posts
    6,888
    Mostly just voltage drop, fault currents, conduit sizing, and budget estimates. Lots and lots and lots of budget estimates.
  6. #6
    Join Date
    Sep 2008
    UK
    Posts
    11,340
    Quote Originally Posted by steve66 View Post
    Maybe you develop them and put them in different folders for commercial and technical?
    My system was to allocate a job number for each enquiry. An EQ number. That was stored on the company network and a unique folder. It stayed as that number even if the enquiry didn't result in an order. All related documentation went in that folder. Just a way to organise it.
  7. #7
    Join Date
    Jun 2003
    Posts
    6,888
    Quote Originally Posted by Besoeker View Post
    Oh, yes. Every project has a number, and every number has a folder on the network, even if its just a proposal that doesn't result in any paid work. It's been that way for at least 20 years now.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
