Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Just starting electrical design
  1. #1
    Join Date
    Apr 2017
    USA
    Posts
    185
    Hello everyone,
    Over the couple of months i have been on this forum i have learned quite a bit regarding NEC and other general topics...I am going to get into design pretty soon..Do you guys have any advice as to how to learn the basic stuff regarding how to design, what needs to be kept in mind while designing a space and any books that could help me in understanding the design apart from Mikeholt NEC code?.
    Thanks in advance for answering my query..
  2. #2
    Join Date
    Mar 2010
    Lake of the Ozarks
    Posts
    1,036
    Quote Originally Posted by shortcircuit1 View Post
    Hello everyone,
    My experience is the best designers have spent a lot of time in the field.
    1N73LL1G3NC3 15 7H3 4BILI7Y 70 4D4P7 70 CH4NG3.
  3. #3
    Join Date
    Apr 2017
    USA
    Posts
    185
    Quote Originally Posted by luckylerado View Post
    Thanks for the advice...Do you know any online courses from the universities that i can take to familiarize myself with NEC and other design aspects?
  4. #4
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    Field experience will not replace any education and education will not replace field experience.
    A good designer has to have both. I don't know how much field experience you, but if you have the chance work in the field as an electrician as long as you can (IMO minimum 4 years) so you get to experience what it takes to install. At the same time take theory and code classes and learn from others. Then switch over full time as a designer.
    Without field experience it is hard to understand and visualize the NEC when the instructor teaches a certain code section.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  5. #5
    Join Date
    Apr 2017
    USA
    Posts
    185
    Quote Originally Posted by edward View Post
    Thanks for the advice ed...I do have some field experience but not a lot...
  6. #6
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    5,813
    The first thing to learn is that the NEC is not a design manual. The NEC is a set of minimum
    safety standards.
    You design for what is needed or wanted and then use the NEC to make sure that your design meets or exceeds these minimum safety standards.
    The 95% of people that you can't trust give the other 5% a bad name.
  7. #7
    Join Date
    Feb 2003
    Posts
    3,279
    Quote Originally Posted by growler View Post
    safety standards.
    Well said!!
    Edward
  8. #8
    Join Date
    Apr 2017
    USA
    Posts
    185
    safety standards.
    I was referring to more like any online courses that have videos of NEC rather than text so that its easier to understand..But thanks...
  9. #9
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,692
    lots of stuff on youtube. some of it you have to be careful about.
    i think mike holt sells some videos. he has some pretty good books I understand.
    Bob
  10. #10
    Join Date
    Apr 2016
    Tampa, Fl
    Posts
    141
    Electrical Design
    After 40 years of installing electrical projects designed by others, I recommend the following standards.
    1. Keep your drawings neat, legible and easy to interpret.
    2. Provide separate drawings for F/A, Communications, Nurse Call Systems, A/V and etc.
    3. Provide as many elevations and details without being redundant.
    4. Communicate with MC and make clear the responsibilities for installation and equipment furnishings between MC and EC.
    5. Design and draw feeder and branch circuitry clearly on prints, indicating home run's and circuit #'s.
    6. Avoid conflicts in the scope of work. Do not bury significant information in the spec's without also noting this information on the drawings.
    There are many other items that should be followed as protocol for each project, many that have nothing to do with an electrical formulas and design.
    Hope this helps and good luck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
