Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: UL Question
  1. #1
    Join Date
    Jul 2012
    cyberspace
    Posts
    163
    UL Question
    I'm looking at a plastic switch plate cover, and it has the little UL symbol.
    What about device screws, are they UL approved as well ?
    What if I take out the short screws, and install 3" long screws for a marble back splash? Do I need to get UL approved screws ?
  2. #2
    Join Date
    Feb 2003
    Fl
    Posts
    16,876
    You don't have to worry about the screws but if your box is that far back you will need a box extender of some type.
    Roger
    Join Date
    Jul 2012
    cyberspace
    Posts
    163
    I'm not worried, I'm curious .......
  4. #4
    Join Date
    Feb 2003
    Fl
    Posts
    16,876
    Quote Originally Posted by spark master View Post
    Well to ease your mind ground screws aren't even listed.
    Note, UL doesn't approve anything, they simply list or recognize items.
    Roger
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,786
    I think you can no longer use something like a drywall screw for such extensions, which works pretty conveniently with plastic boxes, has to be machine thread screw, this would be from NEC
  6. #6
    Join Date
    Jul 2012
    cyberspace
    Posts
    163
    So they list a plastic non-conductive wall plate cover, but they don't list screws ???
  7. #7
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,164
    non-conductive
    Exactly.
  8. #8
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,786
    UL logo is stamped between threads, you need a magnifying glass to see it
  9. #9
    Join Date
    Feb 2003
    Minnesota
    Posts
    6,676
    Sorry, edit to say I misread the OP.
    Switch plate covers supplied screws are probably part of the listing.
    Device screws, supplied with the device are also probably tested and evaluated with the device under it's rating.
    However, I agree that most "fasteners" are not listed by a NRTL. The classic example has already been given above . . . the lowly ground screw for enclosures is not listed, nor does it have to be colored
    Another Al in Minnesota
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,786
    Quote Originally Posted by al hildenbrand View Post
    I'm looking at a plastic switch plate cover, and it has the little UL symbol..
    If said screws are critical to the listing, they should be mentioned in the white book shouldn't they?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
