Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: Multi ground wire splice
  1. #11
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,363
    I would go with the 2-5 wire splices jumpered together. Just use the correct wire nuts.
    Rob
  2. #12
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,800
    Quote Originally Posted by bluecollar84 View Post
    I have a pvc box with 6-8 #12 ground thhn wires that I need to splice what's the best way to do this. Also this jbox is outdoors
    There are all kinds of options.
    Wire nuts and terminal strips are probably the simplest.
    Wire nuts are probably the fastest solution.
    https://www.automationdirect.com/adc...erminal_Blocks
    These are $2-3 each. I think you can get two wires on each side so you would only need two of them and a small piece of DIN rail to mount them on.
    Bob
  3. #13
    Join Date
    May 2011
    Posts
    4,260
    Are those WAGO connectors suitable for outdoor locations?
  4. #14
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,913
    Quote Originally Posted by jaggedben View Post
    Actually, I never gave it a thought. Are wire nuts suitable for outdoor connections?
    Cheers and Stay Safe,
    Marky the Sparky
  5. #15
    Join Date
    Jan 2007
    Posts
    3,531
    Split bolt.
    JAP>
  6. #16
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,363
    Quote Originally Posted by jap View Post
    Split bolt.
    No good for 8-10 conductors although I've seen it done.
    Rob
  7. #17
    Join Date
    Jan 2007
    Posts
    3,531
    Never really thought about it.
  8. #18
    Join Date
    May 2011
    Posts
    4,260
    Quote Originally Posted by K8MHZ View Post
    I believe only those listed for it, such as DryConn.
    I don't think the WAGO are, just wondering if anyone can enlighten with specific info.
    Looking for something better than a Buchanan splice filled with Noalox, which isn't listed but which I personally trust a whole lot more than a wirenut with slippery goop inside.
  9. #19
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,101
    Even twist on connectors probably have similar rating. I have been looking a little but found nothing yet on WAGO site, but wonder if one doesn't need to look in the UL white book.
    I would guess either is rated for use in wet/damp location enclosures, but not in submersible applications.
  10. #20
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    Since the EGC does not have any current flow I can pre-twist them together and confidently use one of these.
    Attachment 17911
    Edward
    The only thing I know, is the progressive discovery of my ignorance
Posting Permissions
  • You may not post replies
  • You may not edit your posts
