Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
Thread: Multi ground wire splice
  1. #21
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,565
    Quote Originally Posted by edward View Post
    Since the EGC does not have any current flow I can pre-twist them together and confidently use one of these.
    Attachment 17911
    I don't know of any wire nut that is listed for more than five conductors.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  2. #22
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,709
    A GBK14 is $8.50. It will take more time than that to get them under two twist ons.
    Tom
    TBLO
  3. #23
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,363
    Attachment 17911
    Quote Originally Posted by ActionDave View Post
    Those 3M Blue/Gray connectors are listed for up to 6-#10 AWG conductors.
    http://solutions.productos3m.es/3MCo...bute=ImageFile
    Rob
  4. #24
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,101
    Quote Originally Posted by bluecollar84 View Post
    Is there an outdoor rated round bar that I can mount in a pvc enclosure ?
    It shoulnd't need to be mounted - doing so with a metal enclosure is a method of bonding to the enclosure. But I guess you still can mount it if you wanted.
  5. #25
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,363
    Is a ground bar required to be rated for damp/wet locations in an outdoor junction box?
    Rob
  6. #26
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    The specs say 6 #10 or #12.
    IMO, it will work especially if the wires are pretwisted.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  7. #27
    Join Date
    Feb 2003
    Posts
    3,279
    I need to correct myself.
    The specs range is from 4 #14 to 6 #10. Not maximum 5#12s.
    If I have done this correctly:
    area of #10 is 10380 so 6 #10s = 62280 circular mils
    area of #12 is 6530 so 8 #12s = 52240 circular mils
    Edward
  8. #28
    Join Date
    Jun 2015
    texas
    Posts
    1,698
    Quote Originally Posted by jaggedben View Post
    Looking for something better than a Buchanan splice filled with Noalox, which isn't listed but which I personally trust a whole lot more than a wirenut with slippery goop inside.
    The red bcaps top out at 5 #12's and the 2011 buchanan crimps can take up to 7 #12's- thought about mentioning those earlier but as Jaggedben pointed out, not 100% on the legality of the goop and the listing of those products....
    OTOH, depending on the circumstances, it may not even be necessary to use any type of sealant/anti cor. Lots of panels are outside, we don't do that to the joints in them, just plain old wirenuts, and no problems.
  9. #29
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,913
    Quote Originally Posted by user 100 View Post
    Other than underground splicing, show me where it says that splices must be waterproof. Connectors, if used, don't even have to be listed, just identified for the use.
    Cheers and Stay Safe,
    Marky the Sparky
  10. #30
    Join Date
    Mar 2008
    Posts
    9,913
    It would be legal to twist all 8 conductors together in a manner that provides all the mechanical integrity necessary for a good connection and then solder them. If the EGC's are bare, nothing more would be required, not even tape.
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
