Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Multi ground wire splice
  1. #1
    Join Date
    Jul 2016
    US
    Posts
    188
    I have a pvc box with 6-8 #12 ground thhn wires that I need to splice what's the best way to do this. Also this jbox is outdoors
  2. #2
    Join Date
    Mar 2003
    New England
    Posts
    13,287
    There is no twist-on connector listed for 8 #12 so your best best is to use a small ground bar kit. It's definitely better than trying to splice that many wires under a twist-on connector anyway, even if you could do it.
  3. #3
    Join Date
    Jun 2015
    texas
    Posts
    1,697
    Quote Originally Posted by bluecollar84 View Post
    I agree w/ Peter d about a bar.
    But if you insist on using wire nuts, you could use a couple of the Dryconn blues with a jumper between them (IIRC those max out at 4 or 5 #12s per unit).
    Last edited by user 100; 07-03-17 at 01:27 AM. Reason: eliminated unnecessary word
  4. #4
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    Quote Originally Posted by peter d View Post
    There is no twist-on connector listed for 8 #12 so your best bet is to use a small ground bar kit. It's definitely better than trying to splice that many wires under a twist-on connector anyway, even if you could do it.
    That or an 8 port WAGO:
    https://www.amazon.com/478047-773-16.../dp/B00HRHXMTU
    afaik, the largest wire nut is rated for 5 #12s. Some are rated for 5 #10s, tho there is no translation for if or how many #12s it could hold.
  5. #5
    Join Date
    Jul 2016
    US
    Posts
    188
    Is there an outdoor rated round bar that I can mount in a pvc enclosure ?
  6. #6
    Join Date
    May 2012
    Amissville, Virginia USA
    Posts
    202
    Is there a product that I can use in my pvc enclosure outdoors for a ground bar ? If so please list link to the products webpage. I only need 8 spot ground bar and how would I mount it to the pvc enclosure ?
    I would use zinc, copper or brass. Just don't use aluminum.
    Sent from my SM-T350 using Tapatalk
  7. #7
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,140
    Every outdoor panel has a bar -- they don't need to be outdoor rated. Just pick up a ground bar from your supplier
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  8. #8
    Join Date
    Jul 2016
    US
    Posts
    188
    It's not a panel board it's just a PVC enclosure J box
  9. #9
    Join Date
    Mar 2010
    Lake of the Ozarks
    Posts
    1,034
    You are over thinking it.
    1N73LL1G3NC3 15 7H3 4BILI7Y 70 4D4P7 70 CH4NG3.
  10. #10
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,847
    Quote Originally Posted by JFletcher View Post
    +1
    Either Wagos or Ideal push ins. Lowe's has Ideal's
    Cheers and Stay Safe,
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
