Results 1 to 3 of 3
Thread: PPE
  1. #1
    Join Date
    May 2009
    Posts
    258
    PPE
    if the incident level is 3.8 cal/cm2 after calculation. is HRC 2 is only required?
  2. #2
    Join Date
    Jul 2015
    Nebraska
    Posts
    59
    According to
    https://www.flameresistantuniforms.c...-rating-chart/
    HRC1 clothing would be sufficient. I think they are getting their info from NFPA 70E.
    Sent from my LGUS610 using Tapatalk
  3. #3
    Join Date
    Jun 2017
    WI, USA
    Posts
    323
    2015 NFPA 70E has clarified: hazard risk categories shall not be used with incident energy method (130.5(C)).
    If you were provided a calculated 3.8, see 70E Annex H: Table H.3(b)  Guidance on Selection of Arc-Rated Clothing and Other PPE for Use When Incident Energy Exposure Is Determined.
    Free NFPA access: http://www.nfpa.org/codes-and-standa...-and-standards
Posting Permissions
  • You may not post replies
  • You may not edit your posts
