Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Two people electrocuted in separate incidents
  1. #21
    Join Date
    Jan 2016
    PA
    Posts
    4,512
    Quote Originally Posted by kwired View Post
    A phone battery I have laying on my desk says it is 3.85 volts, charge volts 4.4 volts. Is that going to push enough current through a human body that is presumably in reasonable health condition to kill them?
    Now if premises supply volts to the charger is somehow imposed on the charging cable (likely malfunction or even cheap non listed component) I can easily see that electrocuting someone.
    not saying that is what killed her, only that it may account for the burns
    the terminals are only mm apart
    so on a wet hand it may see fractions of an Ohm
    so large current, enough to burn
    her body would be in parallel to ground (water/plumbing), so she would see a fraction of that
  2. #22
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,598
    Quote Originally Posted by Ingenieur View Post
    But neither the charger nor the USB or lightning connector outbound power from the battery are able to supply more than a couple of amps. And I really do not see a lot of current at only 5V DC.
  3. #23
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,274
    Quote Originally Posted by GoldDigger View Post
    And then push that current through human flesh that is pretty high resistance, even when sitting in the tub of water it will still at least be several hundred ohms wouldn't it?
  4. #24
    Join Date
    Jul 2006
    Posts
    7,159
    Quote Originally Posted by jaggedben View Post
    I read an article about the girl in the bathtub and thought it didn't make much sense how they were focusing so much on the cellphone. The theories in this thread regarding how she might have gotten 120V to herself in the tub make a lot more sense. Extension cord...
    But "Electrocuted holding a cell phone!" gets a lot more clicks...
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  5. #25
    Join Date
    May 2011
    Posts
    3,859
    Quote Originally Posted by Jraef View Post
    Yes, money matters more than truth these days.
  6. #26
    Join Date
    Sep 2003
    Connecticut
    Posts
    232
    Quote Originally Posted by K8MHZ View Post
    According to the article, there was a burn mark on her hand. I don't understand how that can happen with anything plugged into a cell phone. I wonder if there is a 'rest of the story'?
    Yup. It's in the story: The girl's grandmother, who lives in Texas, told the local TV station that's what had happened, and they picked it up and ran with it. But, as the story notes, it happened in New Mexico, not Texas, while the girl was visiting her father. So, she had a burn on her hand, and the phone was in the bathroom. Was the burn fresh? Was it an electrical burn?
    What this story doesn't say (but I saw elsewhere) is that the medical examiner hadn't ruled on the cause of death.
    So, this is just grandma jumping to conclusions.
    It takes 0.1A to cause fibrillation, assuming (generously) 500 ohms resistance of the girl's body in water, it'd take 50V to kill her. But the charger only gives 5V, and it should have been on a GFCI (was it?).
    BTW, cell phones don't cause your car to blow up at the gas station, either. It's the static discharge arc when you touch the pump handle after sliding out of the car seat.
  7. #27
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,021
    Quote Originally Posted by wtucker View Post
    I see someone else is a Mythbusters fan!
  8. #28
    Join Date
    Jul 2006
    Posts
    7,159
    Quote Originally Posted by gadfly56 View Post
    I miss those guys already. I met them once at their favorite film site (the old Alameda Naval Air Base) about 4 years before they packed it in, they are just like they appear in the show; Jamie is quite and reserved, Adam is animated and outgoing (the younger crew was off somewhere else). But even by then they were getting a little tired of it. Adam said they never thought it would go on as long as it did.
    They would have TOTALLY taken on this issue I think. Did the "new" version of the show ever make it? I know they did a reality competition show to pick the new hosts, then I never heard any more about it.
  9. #29
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,021
    Very briefly they had a Hollywood vs Engineers show going, where the teams had to do a build to achieve certain milestones. I think it had half a dozen episodes.
    I miss them too, but when it stops being fun you have to hang it up. You don't want to bring your audience down because it's now just another job. I still don't understand why the axed Grant et al for the final season or so. I thought the A team B team format worked well.
  10. #30
    Join Date
    Jul 2006
    Posts
    7,159
    It was a salary negotiation issue gone awry. The three of them took a page from the Friends and Big Bang cast tactics to stand firm for all of them getting raises, and Discovery called their bluff.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
