Quote Originally Posted by ShadowSparky View Post
A 20 amp breaker located at the main panel. That would be a different breaker than the GFCI one. I didn't know if it was the spark caused by the time clock making a "sloppy" connection that might trip the GFCI or if I have other issues. This building was built in the 60's but the service was just redone from the CT cabinet to the distribution panels all square D.
Thanks for any help.
I don't understand what you're doing with all the circuit juggling.
You came to a supposedly bad time clock, then you're suspecting the new time clock is also making a sloppy connection. I don't think you need a better quality time clock as much as you need a better quality diagnosis.
