Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: separate sturctures, outside branch circuits
  1. #11
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,263
    Quote Originally Posted by petersonra View Post
    Personally, if it were me I would not mess with it unless there was some really good reason.
    Same here. sounds like distance isn't much of an impact on voltage drop but if it were a MWBC could see some improvement in voltage drop over two separate circuits with same size conductor and same loads.
  2. #12
    Join Date
    Mar 2014
    Baton Rouge, LA
    Posts
    113
    At minimum I think each structure needs it's own disconnect. Am I mistaken with this?
    Quote Originally Posted by kwired View Post
  3. #13
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,263
    Quote Originally Posted by xguard View Post
    Most of the time yes. There are some exceptions mentioned in 225.32. Lighting poles are one common application that doesn't need a disconnect at the separate structure.
    Sevaral times I have ran or seen a single receptacle on a post with no local disconnect, not sure how that is exempted, or maybe it just is let go quite often.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
