Results 1 to 5 of 5
Thread: Paint removal
  1. #1
    Join Date
    Jul 2017
    Menomonee Falls, WI, US
    Posts
    22
    Paint removal
    So there are times and circumstances where it is necessary to remove the paint on an enclosure to have a bonded path with a fitting or lug, but when paint is removed the corrosion protection is also removed, so conductive corrosion resistance has to be added.
    What is the best product to accomplish this?
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,606
    I use a "fraying" tool that goes in a drill, a circular wire brush, quickly cleans to bare metal.
    Then use some Penetrox E, which is a conductive compound under the lug, it will prevent corrosion as it displaces moisture.
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Jan 2017
    Colorado
    Posts
    5
    Same as Tom basically, I put some DE-OX on the cleaned surface. I don't recall an inspector ever bringing this up, but it feels more "pro" I think.
  4. #4
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,584
    Quote Originally Posted by LarrywdH View Post
    only remove the paint on the inside.
    you have a raw edge where you cut a hole for the fitting. did you touch up the paint there?
    Bob
  5. #5
    Join Date
    Jul 2017
    Posts
    22
    "the raw edge"
    No, because I'm not contacting that surface for bonding purposes.
    250.96
    300.6
Posting Permissions
  • You may not post replies
  • You may not edit your posts
