Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: DC Current Safety Threshold
  1. #1
    Join Date
    Aug 2016
    North Augusta, SC USA
    Posts
    25
    I just recently experienced an issue where a researcher used electrical test leads to a DC power supply, and then to two separate electrical probes. The DC power supply was rated at 10 VDC with an amperage up to 40A. The test leads were normal leads used for a multimeter, so when the researcher increased the amperage the test leads begin smoking and were damaged. From my experience test leads used for multimeters are designed for 10A not 40A, so to me this is a expected condition. My question since I am not very familiar with DC voltages, would 10 VDC with a 40A load pose a safety risk to an individual if they connected any exposed terminal.
  2. #2
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    817
    10 volts is very, very, very unlikely to pose any risk of electrocution, regardless of whether it's AC or DC. A device that dissipates 400 watts and connections that carry 40 amps are likely to cause a thermal burn, again regardless of whether it's AC or DC.
  3. #3
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    Quote Originally Posted by Nardie View Post
    Test leads are very small gauge wire, maybe 20 AWG or smaller - they will not carry 40A for any amount of time before the insulation melts. The voltage isnt the issue, the amperage is - anyone holding onto that wire would most likely get burned.
    It's kinda like dropping a Crescent wrench across an automotive battery - you wont get electrocuted, or even shocked - it's still just 12V, but the amperage could be 800 amps or more - exploding battery or molten/hot metal could cause substantial injury.
    otoh, you could run a 40A load, AC or DC, across #6 wire indefinitely without problem, provided high ambient temperature and derating for CCC dont come into play.
  4. #4
    Join Date
    Feb 2012
    Athol, ID
    Posts
    824
    As stated...it's all about current through the body. Higher the voltage, higher the current if you make yourself a circuit. It takes about 0.1 amps to kill, so do the math. But, can you get electrocuted grabbing onto a 12V car battery? YUP! If your hands are sweaty, have acid on 'em and you have a large enough surface area due to the tool you're holding onto. DC is supposedly more dangerous because it is better at sending the heart into fibrillation. All of this is based on our regular safety meetings, though. I'm no Dr. Frankenstein.
  5. #5
    Join Date
    Feb 2013
    India
    Posts
    2,456
    Quote Originally Posted by meternerd View Post
    DC is more dangerous
    At higher voltage than AC, of course.
  6. #6
    Join Date
    Jun 2015
    orlando, florida, usa
    Posts
    57
    Quote Originally Posted by drcampbell View Post
    40amps is 40amps voltage doesnt come into it. the leads to test in line amps on a 40amp circuit would have to be #8awg. Which is why rms amp probes are so popular.
  7. #7
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,056
    Quote Originally Posted by Sahib View Post
    Actually, it's the opposite. DC through the heart is more dangerous than AC.
    Cheers and Stay Safe,
    Marky the Sparky
  8. #8
    Join Date
    Mar 2008
    Posts
    10,056
    Can you show me a single incident where a person was electrocuted by a 12 volt car battery?
    Marky the Sparky
  9. #9
    Join Date
    Feb 2013
    India
    Posts
    2,456
    Quote Originally Posted by K8MHZ View Post
    A defibrillator sends DC through heart to revive cardiac arrest patients.
  10. #10
    Join Date
    Mar 2008
    Posts
    10,056
    Those patients have afib and the DC is in measured pulses of around 5ms. That is totally different from the effects of steady current DC on a healthy person.
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
