Results 1 to 6 of 6
Thread: Three light switches for single room
  1. #1
    Join Date
    Jul 2016
    Wisconsin
    Posts
    11
    I have a room with three doors. I'd like a light switch next to each door to turn on/off the lights when entering/exiting the room. Would I need one 4-way switch, and two 3-way switches? Would it be possible to use three 3-way switches? Thanks.
  2. #2
    Join Date
    Oct 2015
    US
    Posts
    372
    3 -3 way switches will not work u need 3way 4way 3way.
    Sent from my SM-G950U using Tapatalk
  3. #3
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,744
    Taking it a step further, you have to have a 3-way at the beginning and at the end of the run. But you can have as many 4-way switches in between as you wish. Finally, keeping in mind that I have no clue about the prices of such things, you can use nothing but 4-way switches, as long as you wire the first and the last as though they were 3-ways.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  4. #4
    Join Date
    Nov 2016
    Kennewick
    Posts
    63
    This forum is for electricians not homeowners.
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,229
    Quote Originally Posted by blkmagik21 View Post
    OP profile says he is engineering student. Asking a general question of that nature is probably allowed. Asking for DIY advice is not.
  6. #6
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,378
    Quote Originally Posted by rc7288 View Post
    Yes. 3 way, 4 way, 3 way. There's no need to complicate matters by trying to use all 3 or 4 way switches. Is it possible to use 3 3 ways? I dont think so, not without getting into some odd/unconventional/not-code wiring.
    Switches are dirt cheap anyway and any place that sells electrical will have both 3 and 4 way switches.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
